It works!
I had a MS Surface 5 get factory wiped and thankfully we had recent image and file backups thanks to UrBackup. Below is the most basic guide for those in the same position.
- Create most recent USB UR restore drive
- Disable all boot drive options except USB in the surface bios.
- Disable secure boot
- Purchase USB hub/Ethernet adapter. I went with this one and I can confirm it works - ( TECKNET USB to Ethernet Adapter, USB C to Ethernet, Aluminum 3 Port USB 3.0 Hub with RJ45 10/100/1000 Gigabit
- Have spare USB keyboard - Built in surface keyboard and trackpad wont work from select "GUI or Text dialog box on)
- Plug tecknet hub into surface USB port. Plug URrestore USB and keyboard into USB hub.
- Power surface on.
- Enter at first URRestore screen to start.
- Select Text/console based interface. I was lost and dead in the water with GUI because I couldn’t get the GUI to find a network adapter… Maybe I’m an idiot, but text was simply easier.
- Text will also say it cant find your network. I entered my urbackup IP:port. Asked me for login info, and I was good to go. Rest of process is normal.
Hopefully this post helps someone else down the road.
