Hi Guys, i need now realy your help.
Situation is that we are hitting by RAnsomware and we try now to restore the last 1-2 weeks, but we are not able to restore the files and folder.
The Situation with Urback is following :
When we try to restore the files and folder from urbackup, it needs every time hours for indexing and we dont know why. We have Disabled all Antivirus and also i have turned off “Calculate file-hashes on the client:” ( Found here in Forum.
When i restore a single file, all works fast but when i try to restore a simple 8 MB Folder with contend, it needs 4 hours for indexing and than the restore starts.
Sometimes the restore works but most time not.
I see follwing at the logfile :
2020-11-10 05:15:35: ERROR: Error while downloading files during restore
2020-11-10 05:15:35: Channel message: LOG 5-0-Restore failed.
2020-11-10 05:15:35: Restore failed.
2020-11-10 05:16:28: Channel message: FILESERV
2020-11-10 05:16:28: FileSrv: Received data…
2020-11-10 05:16:28: FileSrv: Received a Packet.
2020-11-10 05:16:28: FileSrv: Sending script output (normal) urbackup/FILE_METADATA|0MJxVI6MqnsZCuExbkEejdYoV metadata_id=0
2020-11-10 05:16:28: FileSrv: Mapped name: \tmp\mkmergsdfklrzrehmklregmfdkgfdgwretklödf\FILE_METADATA|0MJxVI6MqnsZCuExbkEejdYoV
2020-11-10 05:16:34: Channel message: RESTORE PERCENT pc=2&status_id=2&id=101&details=&detail_pc=-1&total_bytes=7572681004&done_bytes=133318564&speed_bpms=0
2020-11-10 05:16:44: Looking for old Sessions… 1 sessions
2020-11-10 05:17:28: FileSrv: Error: Sending data failed
2020-11-10 05:17:28: FileSrv: Sending script urbackup/FILE_METADATA|0MJxVI6MqnsZCuExbkEejdYoV not finished yet
2020-11-10 05:17:28: FileSrv: Select Error/Timeout in RecvMessage
2020-11-10 05:17:28: FileSrv: Deleting Memory…
2020-11-10 05:17:28: FileSrv: done.
2020-11-10 05:17:34: Channel message: RESTORE PERCENT pc=2&status_id=2&id=101&details=&detail_pc=-1&total_bytes=7572681004&done_bytes=133318564&speed_bpms=0
2020-11-10 05:18:34: Channel message: RESTORE PERCENT pc=2&status_id=2&id=101&details=&detail_pc=-1&total_bytes=7572681004&done_bytes=133318564&speed_bpms=0
2020-11-10 05:19:34: Channel message: RESTORE PERCENT pc=2&status_id=2&id=101&details=&detail_pc=-1&total_bytes=7572681004&done_bytes=133318564&speed_bpms=0
2020-11-10 05:20:34: Channel message: RESTORE PERCENT pc=2&status_id=2&id=101&details=&detail_pc=-1&total_bytes=7572681004&done_bytes=133318564&speed_bpms=0Info
11/10/20 04:57
Starting restore of path “D\Company Data\CEase\ComputerEase\data”. Waiting for client confirmation…
Errors
11/10/20 05:02
Restore was inactive for 5min. Timeout. Stopping restore…
Found also another issue : The file or directory is corrupted and unreadable. (code: 1392)
Tis is logged at the Client where i want restore the data
2020-11-10 11:49:16: ERROR: Fatal error writing to file in writeFileRepeat. Write error in Chunked File transfer. The file or directory is corrupted and unreadable. (code: 1392)
2020-11-10 11:49:16: ERROR: Error loading “D:\AVG\AVG_Internet_Security_Business_x64_749.exe” ERROR (code: 6)
2020-11-10 11:49:16: ERROR: Error while downloading files during restore
Is anyone out there what can help me please ?
Backup Server is Windows 2012 R2, BITS enabled,
