Restore Client 2.4.2 not seeing NVME drive
I’m trying to restore to a machine with an NVME drive using the latest urbackup restore client 2.4.2. (Just downloaded.) The drive is not seen by the graphical interface or the text interface. Looking through the forums, I saw the suggestion of turning off Secure Boot in BIOS. Unfortunately, this is not an option on the latest Dell computers. (“Legacy boot is not supported on this platform.”)
To solve this particular instance of this problem, I can get a SATA SSD, restore to it, and make the NVME drive a second disk. However, I can’t do this for all my future machines.
Did I miss a solution somewhere?
I’d start with googling Laptop model + Linux NVMe.
Does lsblk list it? Ist there info in dmesg about it?
Rebooted to the restore graphical client and opened a terminal. lsblk doesn’t see it and dmesg says “Operation not permitted.” It’s quitting time, so I’ll boot xbuntu live tomorrow so I have root. I’ll let you know.
OK, the problem is not with NVMe drives, the problem is with Intel Rapid Store Technology being enabled in BIOS. Once I switched it off, the URBackup Restore environment can see the NVMe disk without a problem.
Ubuntu has a pretty complete write up on the issue. (Which is how I discovered the issue. Xubuntu live environment couldn’t see the drive either, so I attempted to install xubuntu and it pointed me to this writeup: Intel RST )
I finished the first half of the instructions on that page, making changes to the registry before I switched to AHCI mode in the BOIS. Windows 10 won’t boot now, so I have some steps to take before I try the restore.
I will update as I go along.
To Busy To Read The Whole Thing Summary:
(Works on a Dell Precision 3650, your mileage may vary.)
  1. Insert the URBackup Restore CD/USB Drive
  2. Boot to BIOS
  3. In the Storage category, switch from Intel Rapid Storage Tech (RAID On) to AHCI
  4. Enable boot from the CD/USB Drive
  5. Boot to the URBackup Restore client and restore per instructions
  6. Shut down the computer and remove the CD/USB Drive.
  7. Boot to BIOS
  8. Switch Storage from AHCI back to Intel Rapid Storage Tech (RAID On)
  9. Reboot to a restored Windows 10.
This morning I tried the rest of the ubuntu instructions mentioned in this thread without success. The volume couldn’t be activated, and there was no safeboot value for bcdedit to delete. Instead of trying to manually create a new bootloader file with bcdboot, I decided to try the method above, and it worked for me.
Same as here then, I guess
I think it would work on Linux with either dmraid or mdadm. It would be great to have it detect such a fake RAID automatically. But without having the actual hardware to test on I cannot do that, so I guess someone with it has to add it.
This worked with my Lenovo Yoga (SanDisk A400 NVMe PCIe Gen 3.0 x4), changing from RAID to AHCI, restoring with urbackup, changing from AHCI back to RAID. Reboot.
Since my usb drive was also a SanDisk, I originally selected this disk (the only option available) and couldn’t figure out why urbackup was just sitting there at 94% cpu but accomplishing nothing. This looks like a bug or else maybe there is a use case where one would restore to their urbackup restore boot disk?
I’m glad this issue was resolved but this is Not a ‘Solution’. This is a hack.
I’ve got similar issues on a production server for a customer with VROC NVMe and there is no Solution due to URBackup restore media being unable to inject / add drivers (specifically Intel VROC NVMe drivers).
There is a method to build / compile a custom restore image but there are virtually zero guidance and no step-by-step for doing this especially for us life-long Windows engineers which is really disappointing given to potential URBackup has to make in-roads into the enterprise class customers.
Lastly, to compound this issue further, it’s highly likely that beginning in 2026, None of these URBackup Retore images will boot on modern (and UEFI FW updated) servers due to BlackLotus Boot Hole security fixes where older Windows and Linux Boot Loaders will Not be allowed to boot due to Boot Loader Revocation within the UEFI DBX (Disallow list) which will make URBackup moot as customers begin updating their FW beginning in 2026 and later (could even begin sooner).
In short, there must be an updated Restore image with current Linux boot loader and include drivers like Intel VROC NVME (and SATA) drivers and/or a method to build the Restore image (like every other Backup/Restore app) and pull the required drivers (or add them) while creating the Restore media… and/or at the very minimum, provide detailed step-by-step instructions to build and inject / add drivers into a custom restore media image.
Ah yes I agree with RJR that it’s an annoying faff to turn off secure boot for each restore. Not the end of the world for me (single user) but not great. Also as I mentioned elsewhere, the old client image is lacking important network chipset drivers - RTL8125 is missing too which is being used everywhere in modern motherboards
In our customer scenario, turning of Secure Boot does not address or resolve the issue. This is a fundamental failure of UrBackup. The VROC drivers are just not available within UrBackup (which could be due to Linux drivers versions, etc.) but more importantly, cannot be injected as there are no meaningful instructions for doing so or creating a custom UrBackup Restore media within UrBackup Documentation / Help.
Finally, after about 1.5 months of monkeying with UrBackup the customer broke-down and bought a subscription to Macrium. We selected and injected the VROC NVMe driver into the custom restore media, created bootable USB flash drive, booted, restored and were done in about 1 hours. Problem Solved.
Essentially, egg on my face for suggesting to use UrBackup to save $$$ for the customer. All UrBackup needs to do is to provide meaningful step-by-step guide for injecting a Linux driver into a custom Restore media image and this would have been a done deal and another satisfied UrBackup user but it’s water under the bridge now. Again, it’s too bad as UrBackup has potential.
Any update on this? I haven’t seen any new version (or its release notes) where new drivers are mentioned?
No update on this. Not a peep from URBackup; just radio silence. I expect URBackup to go the way of the Dodo bird here fairly soon as Boot Loader UEFI Certificate (PCA2011) goes end-of-life June 2026 and most server / system OEMs have already begun updating their UEFI PCA boot loader certificates to the new PCA2023 certificates.
Currently server / systems will use both PCA2011 and PCA2023 and boot both older or newer OS images when Secure Boot is Enabled (for both Windows and Linux OS SKUs). Migrating to the new PCA2023 CA cert is currently optional but will become forced / enabled by default very soon.
This means that when the server’s FW is updated to a later version that implements the new PCA2023 CA, then, (when) PCA2011 is added to the ‘Disallow’ (DBX) list within UEFI, (prior to June 2026), then when Secure Boot is Enabled (most major Linux streams support Secure Boot), No Older OS backup images based upon PCA2011 will Boot when Secure boot is Enabled! Period, unless you Disable Secure Boot. (there is both a UEFI and OS Kernel component to this)
In short, As much as I loved URBackup in the past, they’re antiquated and quickly making themselves irrelevant.
  • URBackup doesn’t keep themselves updated with necessary industry standards
  • URBackup won’t add basic features like driver injection
  • URBackup won’t provide meaningful steps / documentation about how to create a custom Linux bootable image and inject drivers (step-by-step)
  • URBackup probably won’t update Rescue Media to a current version that includes (both) PCA2011 and PCA2023 for quite some time (probably isn’t even aware of PCA2011 issues).
  • URBackup support doesn’t effectively respond to cries for help. Goes radio silent.
  • On and on…
Below are MS articles about the PCA2011 boot loader revocation and replacement PCA2023 but it applies to Linux as well. Direct daytime job engagement with MS confirms this.
The only hope for URBackup is to address all of the above. Especially the PCA boot loader cert and driver injection, else both their free and paid versions are toast going forward.
