Hi:
I am testing urbackup at kvm virtual machine. the virtual machine is running microsoft windows as urbackup client.
the virtual machine use kvm virt-io disk, and under urbackup restore cd the disk name is vda. but the restore program didn’t recognize vda as valid disk and it said there is no hard disk to restore. if I change the virtual disk type to sata (so the disk name become sda under linux), then restore is fine.
since the vda is already seen by resotore-cd linux, I think the fix maybe easy. is there easy way to fix it? which file should I modify?
thanks a lot for help!!
