Ok so for the port binding issue I can reproduce this now and it’s not limited to restart itself. The issue seems to be tcp connections that remain from computers connecting to the web interface after the daemon is stopped.
Steps to reproduce:
Go to the urbackup interface from any computer browser.
Restart the urbackup_srv “invoke-rc.d urbackup_srv restart” or stop and start.
urbackup_srv fails to bind to port 55414
Leave it it for a few seconds until the tcp connections from the client computer expire.
Start urbackup_srv and it binds to 55414.
See below output - this is long sorry as I had some unexpected errors when I went to create this thread and have included them.
I stop the server daemon and check no tcp sessions on 55414.
myriad> invoke-rc.d urbackup_srv stop
myriad> netstat -tap | grep 55414
myriad>
I then start it and connect to the web interface.
myriad> invoke-rc.d urbackup_srv start
tcp 0 0 *:55414 *:* LISTEN 10281/urbackup_srv
tcp 592 0 myriad.happytreas:55414 10.39.41.107:51830 ESTABLISHED -
At this point the interface is unresponsive and the browser reports it is waiting…
I wait about 20 seconds and try to refresh the page and hit enter on the address and netstat shows this:
tcp 593 0 myriad.happytreas:55414 10.39.41.107:51830 CLOSE_WAIT -
tcp 592 0 myriad.happytreas:55414 10.39.41.107:51837 ESTABLISHED -
tcp 593 0 myriad.happytreas:55414 10.39.41.107:51836 CLOSE_WAIT -
I try again a few seconds later…
tcp 593 0 myriad.happytreas:55414 10.39.41.107:51837 CLOSE_WAIT -
tcp 592 0 myriad.happytreas:55414 10.39.41.107:51853 ESTABLISHED -
I stop the daemon and check for tcp sessions
myriad>
I start the daemon again and check that it’s listening:
tcp 0 0 *:55414 *:* LISTEN 10352/urbackup_srv
I connect to the web interface about 20 seconds later and it works. netstat shows this:
tcp 0 0 myriad.happytreas:55414 10.39.41.107:51871 TIME_WAIT -
tcp 0 0 myriad.happytreas:55414 10.39.41.107:51873 TIME_WAIT -
tcp 0 0 myriad.happytreas:55414 10.39.41.107:51872 TIME_WAIT -
I stop the daemon, check netstat, start the daemon and check netstat.
The server fails to bind on 55414 as you can see but the old sessions are still there. I wait about 30 seconds and then check netstat.
myriad>
No tcp sessions on port 55414 so I start the daemon… OK at this point something unexpected happens the daemon made one CPU core run at 100% and even though there were no tcp sessions on 55414 and still failed to bind to the port.
the log output is as follows:
01/31/12 22:01:23: WARNING: Shutting down (Signal 15)
01/31/12 22:01:23: Exited Loop
01/31/12 22:01:23: Deleting at..
01/31/12 22:01:23: Deleting SelectThreads..
01/31/12 22:01:23: Deleting lbs...
01/31/12 22:01:23: Shutting down plugins...
01/31/12 22:01:23: Stopping channel...
01/31/12 22:01:23: Lost channel connection to client. has_error=true
01/31/12 22:01:24: server_prepare_hash Thread finished
01/31/12 22:01:24: server_hash Thread finished - exitnow
01/31/12 22:01:24: server_get Thread for client 3MMEL-TP01 finished
01/31/12 22:01:25: Deleting server...
01/31/12 22:01:25: deleting cached settings...
01/31/12 22:01:25: deleting stream services...
01/31/12 22:01:25: ServiceAcceptor finished
01/31/12 22:01:25: HTTP: Waking up...92438
01/31/12 22:01:25: ServiceWorker finished
01/31/12 22:01:25: c=0/2
01/31/12 22:01:25: c=1/2
01/31/12 22:01:25: c=2/2
01/31/12 22:01:25: deleting plugins...
01/31/12 22:01:25: Deleting threadsafe plugins...
01/31/12 22:01:25: Deleting pluginmanagers...
01/31/12 22:01:25: Deleting actions...
01/31/12 22:01:25: Deleting sessmgr...
01/31/12 22:01:25: removing sessions...
01/31/12 22:01:25: done.
01/31/12 22:01:25: waiting for sessionmgr...
01/31/12 22:01:25: Shutting down ThreadPool...
01/31/12 22:01:25: destroying databases...
01/31/12 22:01:25: deleting database factories...
01/31/12 22:01:25: unloading dlls...
01/31/12 22:01:25: Destroying mutexes
01/31/12 22:01:31: Changing user...
01/31/12 22:01:31: done.
01/31/12 22:01:31: Loaded -pychart- plugin
01/31/12 22:01:31: Loaded -url- plugin
01/31/12 22:01:31: Loaded -download- plugin
01/31/12 22:01:31: Loaded -fsimageplugin- plugin
01/31/12 22:01:31: Starting HTTP-Server on port 55414
01/31/12 22:01:31: ERROR: HTTP: Failed binding SOCKET to Port 55414
01/31/12 22:01:31: Starting as server...
01/31/12 22:01:31: Started UrBackup...
01/31/12 22:01:32: Creating SOCKET...
01/31/12 22:01:32: done.
01/31/12 22:01:32: Server started up sucessfully!
01/31/12 22:01:32: Looking for old Sessions... 0 sessions
01/31/12 22:01:32: New Backupclient: 3MMEL-TP01
01/31/12 22:01:32: Getting client settings...
01/31/12 22:01:32: Sending backup incr intervall...
I stop the daemon which stops the CPU going mad and start the daemon again. This time its happy and is not thrashing the CPU and binds to 55414.
tcp 0 0 *:55414 *:* LISTEN 10545/urbackup_srv
I connect to the web interface ok again.
I restart the daemon and it fails again:
tcp 0 0 myriad.happytreas:55414 10.39.41.107:52008 TIME_WAIT -
tcp 0 0 myriad.happytreas:55414 10.39.41.107:52013 TIME_WAIT -
tcp 0 0 myriad.happytreas:55414 10.39.41.107:52012 TIME_WAIT -
tcp 0 0 myriad.happytreas:55414 10.39.41.107:52011 TIME_WAIT -
myriad> invoke-rc.d urbackup_srv restart ; sleep 3 ; netstat -tap | grep 55414
Restarting UrBackup server deamon: urbackup_srv.
tcp 0 0 myriad.happytreas:55414 10.39.41.107:52021 TIME_WAIT -
tcp 0 0 myriad.happytreas:55414 10.39.41.107:52015 TIME_WAIT -
tcp 0 0 myriad.happytreas:55414 10.39.41.107:52018 TIME_WAIT -
tcp 0 0 myriad.happytreas:55414 10.39.41.107:52014 TIME_WAIT -
tcp 0 0 myriad.happytreas:55414 10.39.41.107:52020 TIME_WAIT -
tcp 0 0 myriad.happytreas:55414 10.39.41.107:52017 TIME_WAIT -
tcp 0 0 myriad.happytreas:55414 10.39.41.107:52016 TIME_WAIT -
tcp 0 0 myriad.happytreas:55414 10.39.41.107:52019 TIME_WAIT -
tcp 0 0 myriad.happytreas:55414 10.39.41.107:52022 TIME_WAIT -
