i’ve got multiples clients who was on personal (individual) settings option (checked).
For exemple, for the option : exclude_files
but now, i want my clients will be all on globals (default) settings.
When i uncheck the “individual settings” option, the exclude_files not update to the global (default) value, and my client stay with old value…
As a workaround : Can you try creating a group and putting your clients in that group?
Should be like 4 clicks, the new group will inherit the default setting and you can mass select the client and put them in that group
