Remote client not responding to server port 35622 request
. 0.24 server and 0.38 client.
. Local client backing up ok
. Remote client added from Status->Show Details page but is never reached by server.
. Remote client is via OpenVPN.
. Tested with remote XP FW down
. Remote client is XP Home Edition
. Tcpdump show the packet heading out to the client from the server
. Hitting client on wrong port gets proper port not up error so appears client is up
. Monitoring on all server interfaces does not show any client packets coming in on wrong interface
. Have not tried any other remote clients
Any idea why client is not responding to server UDP ping or what I can do to diagnose this issue?
I don’t really have any idea.
I use OpenVPN with a bridge device on my backup server and it even detects a connected PCs automatically.
Does that mean the packets get sent to the correct port (35622) but never arrive? (iptables problem?)
[quote=“uroni”]I don’t really have any idea.
Does that mean the packets get sent to the correct port (35622) but never arrive? (iptables problem?)[/quote]
Sorry, just ,meant I tried an invalid port to make sure I was reaching the client. Tried removing any iptables rules that might be in the way with no luck.
My OpenVPN is not bridged, but routed. Maybe need to test a second PC not on same subnet and not using OpenVPN. Different subnet appears to be the only common factor on my end.
Just tried a Windows 7 PC on a different network with a different subnet and it worked no problem.
Does the client log anywhere that it is getting the server UDP pings?
Yes if you set the loglevel to “debug” in “args.txt” it logs that into “debug.txt”
Ok,
Debug.txt says:
09/14/11 18:27:35: Receiving UDP packet…
09/14/11 18:27:35: UDP: PING received… sending PONG
WireShark running on the PC shows the outgoing packet.
If I use NC on the PC I can not get any UDP traffic over OpenVPN/Tap interface, but can by just shooting the UDP packet out over the PC’s primary interface to my remote server.
I’ve tried a different version of OpenVPN with the same results.
So, at this time, looks to be OpenVPN/Tap related, nothing to do with Urbackup. I’ll dig into that end, but not getting any good ideas from Google yet :). Maybe I will try running OpenVPN bridged :).
Thanks,
JES
