Hi there,
since a few years I run happily a LAN-based Urback-Debian-Server with Linux/Windows CBT and partly macOS clients. Due to extended requirements, an Urbackup offsite-backup in parallel to the LAN-based setup is needed. In detail, the scenario should look like this:
- LAN-based setup: Urback-Debian-Server with Linux, Windows CBT and partly macOS clients
- Offsite setup: Urbackup Local (=LAN-based) Appliance that stores in a S3-compatible cloud storage
According to “I want to use more then one backup server. What do I have to consider?” in FAQ I would consider: “use the same key and private/public key pair for all backup servers”.
… and now to my questions:
(A) Will a client backup to both Urbackup-Servers simultaneously if both servers are up and running?
(B) If one backup server is down and only the other backup server is available, what happens then?
(C) When a client uses Access/Restore backup from the system tray menu (right click) will the client see both Urbackup Servers and could choose which to use for a restore or will the client see a “merged view” of both Urbackup-Servers?
Thanks in advance for providing me some help on my questions.
