I need to run “urbackupsrv remove-unknown”.
The only way I found with the urbackup docker install is to stop the container with the default entrypoint to run the server and start another one based on the same image but with “/usr/bin/urbackupsrv remove-unknown” as entrypoint.
Is there another way to run remove-unknown foa urbackup docker install? (though I believe supporting running “usrbackupsrv remove-unknown” as a one-shot container entrypoint is good)
This start the remove-unkown fine but I have a permission issue because with this entrypoint the urbackupsrv runs urbackupsrv with uid 101 and my urbackupsrv main container run with PUID=1002 thus my DB are owned by uid 1002
It seems to me that when called with remove-unknwon, the container PUID has no effect. Could it be made to run as PUID even when not run as a daemon?
version: '2'
services:
urbackup:
image: uroni/urbackup-server:latest
container_name: urbackup_remove-unknown
entrypoint: /usr/bin/urbackupsrv remove-unknown
environment:
- PUID=1002 # Enter the UID of the user who should own the files here
- PGID=100 # Enter the GID of the user who should own the files here
- TZ=Europe/Paris # Enter your timezone
volumes:
- /srv/dev-disk-by-label-secure/appdata/docker/urbackup/etc_default_urbackupsrv:/etc/default/urbackupsrv
- /srv/dev-disk-by-label-secure/appdata/docker/urbackup/var_urbackup:/var/urbackup
- /srv/dev-disk-by-label-secure/appdata/docker/urbackup/var_log:/var/log
- /srv/dev-disk-by-label-secure/backup/urbackup:/backups
cap_add:
- SYS_ADMIN # Activate the following two lines for BTRFS support
I get this output:
docker start -a urbackup_remove-unknown
2024-05-17 19:26:55: Going to remove all unknown files and directories in the urbackup storage directory. Waiting 20 seconds...
2024-05-17 19:27:15: Shutting down all database instances...
2024-05-17 19:27:15: Opening urbackup server database...
2024-05-17 19:27:15: SQLite: recovered 19574 frames from WAL file /var/urbackup/backup_server.db-wal code: 283
2024-05-17 19:27:31: SQLite: recovered 155803 frames from WAL file /var/urbackup/backup_server_files.db-wal code: 283
2024-05-17 19:27:31: SQLite: recovered 3701 frames from WAL file /var/urbackup/backup_server_link_journal.db-wal code: 283
2024-05-17 19:27:32: SQLite: recovered 23085 frames from WAL file /var/urbackup/backup_server_links.db-wal code: 283
2024-05-17 19:27:32: SQLite: recovered 323 frames from WAL file /var/urbackup/backup_server_settings.db-wal code: 283
2024-05-17 19:27:33: SQLite: recovered 19574 frames from WAL file /var/urbackup/backup_server.db-wal code: 283
2024-05-17 19:27:33: SQLite: recovered 323 frames from WAL file /var/urbackup/backup_server_settings.db-wal code: 283
2024-05-17 19:27:33: WARNING: SQLite: statement aborts at 10: [DELETE FROM misc WHERE tkey=?] attempt to write a readonly database errorcode: 8
2024-05-17 19:27:33: ERROR: Error in CQuery::Execute - attempt to write a readonly database Stmt: [DELETE FROM misc WHERE tkey=?]
2024-05-17 19:27:33: WARNING: SQLite: statement aborts at 9: [INSERT INTO misc (tkey, tvalue) VALUES (?, ?)] attempt to write a readonly database errorcode: 8
2024-05-17 19:27:33: ERROR: Error in CQuery::Execute - attempt to write a readonly database Stmt: [INSERT INTO misc (tkey, tvalue) VALUES (?, ?)]
2024-05-17 19:27:33: ERROR: LMDB: Failed to open LMDB database file (Permission denied)
2024-05-17 19:27:33: ERROR: LMDB error creating env
2024-05-17 19:27:33: ERROR: Error creating file index
2024-05-17 19:27:33: ERROR: Setting up file index failed
2024-05-17 19:27:33: Error opening files index...
2024-05-17 19:27:33: ERROR: Error cleaning up.
sudo ps -eo user:15,pid,%cpu,%mem,vsz,rss,tty,stat,start,time,comm |grep urbackup
systemd-timesy+ 2775637 7.4 0.2 99772 9088 ? Ssl 19:41:56 00:00:00 urbackupsrv
grep systemd /etc/passwd
systemd-timesync:x:101:102:systemd Time Synchronization,,,:/run/systemd:/usr/sbin/nologin
ls -l /srv/dev-disk-by-label-secure/appdata/docker/urbackup/var_urbackup/fileindex/
total 222340
-rw-r--r-- 1 docker_u users 227405824 17 mai 11:11 backup_server_files_index.lmdb
-rw-r--r-- 1 docker_u users 262208 17 mai 16:53 backup_server_files_index.lmdb-lock
