Hey so I have two Hyper-V’s running, replicating each other using the Microsoft Hyper-V replication.
I’m using the commercial Hyper-V Urbackup Client.
I have three Urbackup servers running, one only backing up my first hyper-v, one only backing up my second hyper-v and one backing up both (first and second hyper-v) to a external drive.
When starting a Backup for a VM on the second Hyper-V via the Interface, it just says “Starten der Sicherung fehlgeschlagen” without any error code. The first hyper V backs up just fine.
Looking at my server_idents, there is one (of two) idents that is the same on Hyper-V 1 & 2, that seems to be my external drive urbackup server.
Because the VM’s are getting replicated, they also have the same hostname, maybe that is part of the problem?
Server logs (clean start with debug options, then started backup via Interace):
Unfortunately could not download the debug log file anymore (link expired).
From the description and the server log file I’d guess it is just UrBackup - Frequently asked questions . You could confirm by enabling the “Status” column on the server where it does not work.
The fix would be to add the server identity to the file.
When activating the “Status” column, I can see that my Hyper-V says “ok” while the vm’s all say “Starting up client”. My server idents seem to be correctly set, I’ve also removed and readded them already.
Edit: when i look on my other urbackup servers, “Status” shwos “ok”, also for the vm’s
I work in an IT service provider business and we’re currently getting our customers to buy the Hyper-V client. We have multiple customers with the same constellation (two hyper’-v’s replicating each other and 3 urbackup servers).
Is there any deadline for this feature? We can’t really recommend the hyper-v client to our customers if the issue persists.
Sorry for the popups, I use an adblocker myself (uBlock Origin) and didnt see any ads/popups.
