Hi there. Plz help me.
I have URBackup server on Windows and i want to migrate db to new larger disk. For now db is on disk D and i had connected new disk F and hadmigrated all the stuff to it by instruction from manual:
https://www.urbackup.org/administration_manual.html#x1-9500010.8
“Create a file named “migrate_storage_to” in /var/urbackup or C:\Program Files\UrBackupServer\ urbackup with the only content of the file being the path where you want to migrate the backups to. Afterwards restart UrBackup server and the migration should begin. You can see the migration progress on the activities page. After the migration is finished change the backup storage path to the new location in the settings or mount the new backup storage at the old location. Afterwards run “remove unknown”” - did it.
Aftrerwards i have disconnected disk D and about 80% of data hava been lost in web interface. But when i connect disk D reverse, all the data is ok.
What i did wrong?
