Problems Web Management recovery
I’m having trouble to see and restore data from the web management…
See the pictures:
Backup exist on the server, but is not show in the Web… How can i fix this?
@uroni how can i fix this?
1 - Restart any service?
2 - How log show it?
Thanks…
I think i had the same bug. Just after the install, If you created the group before setting the backup path.
If server is in a group, delete the group, re-create it, put server inside and it s fixed.
Thanks man,
All clients are fixed !
