! Problems Now With urbackup_tmp_files
Damn it! Everything working fine yesterday morning. Computer only used for backups. Latest UrBackup v.2.4.13 server using a BTRFS filesystem for backups. I have plenty of space on single partition btrfs filesystem (~20% of 6.5TB). I don’t know how many file descriptors are available, but lsof | wc -l returns 17058. Rebooted. Now I get multiple lines in log file:
WARNING: Error opening temporary file. Retrying…
and last line is:
ERROR: Error deleting directory “/urbackup/urbackup_tmp_files”
So, I thought I would use CLI to delete and recreate the temporary directory. As root, if I use either “rm -r” or “rmdir”, I get a response of a Read-only filesystem.
Since the directory is not a subvolume, I assumed “btrfs subvolume delete” wouldn’t work, but… I tried it anyway:
“btrfs subvolume delete /urbackup/urbackup_tmp_files/”
but get:
ERROR: not a subvolume: /urbackup/urbackup_tmp_files/
btrfs fi df -h /urbackup/
Data, single: total=6.20TiB, used=5.08TiB
System, DUP: total=8.00MiB, used=704.00KiB
Metadata, DUP: total=46.00GiB, used=18.76GiB
GlobalReserve, single: total=512.00MiB, used=0.00B
What can I do to recover my situation? Thank you!
Also, dmesg gives me:
segfault at 55868cd07a9b ip 000055865dce9be7 sp 00007ffdd8d73840 error 4 in btrfs[55865dc9d000+a9000]
Does mount | grep urbackup indicate that the filesystem is mounted read-only? In this case, you’d need to somehow recover your (corrupted?) BTRFS. BTRFS Wiki recommends this blog-post: http://marc.merlins.org/perso/btrfs/post_2014-03-19_Btrfs-Tips_-Btrfs-Scrub-and-Btrfs-Filesystem-Repair.html
Yes, it is in readonly - Also, looking at dmesg I can see that it was forced to readonly. I’ve tried btrfs scrub and find that the partition has 4 uncorrectable errors. Then, trying btrfs check --repair ends in a segmentation fault.
I only have one drive at this time. Thanks for the link - I will check it out.
I ended up mucking it up while trying to repair it. I just can’t seem to run urbackup to a btrfs partition longer than a year or so before the filesystem forces itself to readonly. I’ve never had an issue (with filesystem corruption) using ext4 for a file server. Not the same workload, but not idle very long either.
I ran mkfs.btrfs on the partition and am starting over. Again. I’ll feel better in a few days when all clients have had a chance to backup.
3 years forward, how is your experience with btrfs?
I also get this error, but it doesn’t seem to affect anything:
ERROR: Error deleting directory “/storage/urbackup/urbackup_tmp_files”
I don’t get the first error you mentioned though, about opening it.
My relationship with the BTRFS has been better - I don’t use it. I am sure it hates me and the feeling is mutual :slight_smile:
Since I don’t find anyone else with issues, I have made peace that I am the problem. Other than replacing an aged-out drive recently, I can’t think of any problems I have had after abandoning that file system. YMMV.
