Hello everyone!
First of all thank you for the great backup solution UrBackup offers.
I have found similar questions about my problem described below in the forum, but no suitable answer/solution.
Environmental conditions:
- Server version: 2.4.12 (as Docker Container in OMV 4.1.34)
- Client version: 2.3.4 (on Windows 10 PC)
Target state:
Since the Windows machine running Ur-Backup CLient is often not in the same LAN network as the UrBackup server for a long time, I would like to use the possibility to generate backups via the Internet in addition to the already perfectly working local backups.
The WebUI should not be publicly accessible and no other port should be opened besides the already opened port 443.
Actual state:
- backup server settings:
- Internet auth key has been checked several times for consistency and has also already been changed
- port mapping via nginx and Let’s-encrypt
Port 55415 was released via port 443 using nginx
My urbackup.subdomain.conf:
server {
listen 443 ssl;
listen [::]:443 ssl;
server_tokens off;server_name my-urbackup-server.*; include /config/nginx/ssl.conf; add_header Strict-Transport-Security max-age=15768000; location / { include /config/nginx/proxy.conf; resolver 127.0.0.11 valid=30s; set $upstream_urbackup urbackup ; proxy_pass http://192.168.178.10:55415; }}
- settings UrBackup Client:
- Internet auth key has been checked several times for matching and has also been changed
- settings Windows PC:
- Firewall is deactivated
Problem description:
If the client is in another network (hotspot via smartphone), it establishes a connection to the server and indicates that it is connected to the server, but the server displays the client as offline in the WebUI. No backups can be backed up by the client.
In the client debug log, I was able to identify the following entries, which I think are crucial (instead of “my-urbackup-server” the correct address is displayed):
2020-02-24 18:10:11: Trying to connect to internet server “my-urbackup-server” at port 443
2020-02-24 18:10:11: Successfully connected.
2020-02-24 18:10:21: Error receiving challenge packet
2020-02-24 18:10:21: InternetClient: Had an auth error
In the server debug log, I think the following entries are decisive:
2020-02-24 17:27:45: New Backupclient: ThinkPad-PC
2020-02-24 17:30:03: Looking for old Sessions… 1 sessions
2020-02-24 17:30:50: Socket has error: 113
2020-02-24 17:31:00: Socket has error: 113
2020-02-24 17:31:10: Socket has error: 113
2020-02-24 17:31:20: Socket has error: 113
2020-02-24 17:31:30: Socket has error: 113
2020-02-24 17:31:40: Socket has error: 113
2020-02-24 17:31:50: Socket has error: 113
2020-02-24 17:32:00: Socket has error: 113
2020-02-24 17:32:10: Socket has error: 113
2020-02-24 17:32:20: Socket has error: 113
2020-02-24 17:32:30: Socket has error: 113
2020-02-24 17:32:30: ERROR: Connecting to ClientService of “ThinkPad-PC” failed: Querying client capabilities failed
I already tried to manual configure the client and I also downloaded the preconfigured client and reinstalled it on the windows machine without success.
My questions:
Unfortunately I could not find any explanation for the error entries in the log files. Does anyone know what I have configured incorrectly or what changes are necessary to get this configuration running?
I have seen in the settings of the server, which i have updated recently, that there is now also the setting “Connect via HTTP(s) proxy”. Unfortunately I did not find any information about what I have to enter in this field to use this option. All test entries were rejected by the system.
Is my project possibly feasible using this function? If so, what must be entered in this field?
Thanks a lot for your help.
If any information is missing, please let me know.
Greetings,
Michael
