Problems backing up non-system volumes
First off, GREAT PROGRAM! I love UrBackup a lot but I am having a problem getting it to backup any volumes other than C. I have UrBackup Server version 0.26 and UrBackup Client version 0.40. I know this functionality is supposed to be supported in these latest versions. The server service is running on a 2008 R2 VM (firewall off) and the clients are physical 2003 server. My server settings are:
Backup storage path: E:\UrBackupImages
Do not do image backups:
Do not do file backups:
Automatically shut down server:
Autoupdate clients:
Max number of simultaneous backups: 10
Max number of recently active clients: 100
Nondefault temporary file directory:
Cleanup time window: 1-7/3-4
Automatically backup UrBackup database:
Interval for incremental file backups 5 hours
Interval for full file backups 30 days
Inverval for incremental image backups 7 days
Interval for full image backups 60 days
Maximal number of incremental file backups 100
Minimal number of incremental file backups 40
Maximal number of full file backups 10
Minimal number of full file backups 2
Maximal number of incremental image backups 30
Minimal number of incremental image backups 4
Maximal number of full image backups 5
Minimal number of full image backups 2
Delay after system startup 0 min
Backup window 1-7/0-24
Excluded files (with wildcards)
Included files (with wildcards)
Default directories to backup
Volumes to backup C;D;E
Allow client-side changing of the directories to backup
Allow client-side starting of file backups
Allow client-side starting of image backups
Allow client-side viewing of backup logs
Allow client-side pausing of backups
Allow client-side changing of settings
When I install the client on the 2003 servers and it finds the UrBackup server, it immediately creates an image backup of C ONLY. If I then right-click the system tray icon on the 2003 server and tell the UrBackup client to do a full image backup, it STILL only ever does the C volume. Am I missing something?
JU
Sorry to hear that.
Can you please go to the client specific settings page on the server web interface. Those are the settings that actually are used even if they are greyed out. If “Volumes to backup” is only “C” there then it’s a settings error. Otherwise I’ll have a look what else could be wrong.
Both client and server settings are set to C;D;E and all machines being imaged do indeed had a C:, D: and E: drive.
J
I just tested it with my Windows 2003 VM instance and unfortunately it works for me.
Are those volumes not formated with NTFS or not basic volumes (dynamic volumes, GPT instead of MBR)?
They are dynamic volumes… I guess that’s not supported? Don’t see anything in the documentation about dynamic volumes.
J
I’ve tested it with mirrored dynamic volumes. Other types of volumes would be very difficult to support. Are there any log messages in C:\Program files\UrBackup\debug.log with regard to imaging? I’ll fix the documentation.
