Hello all,
I just upgraded my Urbackup sever from version 1.4.8 to 2.0.33. At the same time, I am trying to upgrade my clients, on my workstations, from version 1.4.8 to 2.0.32. However on some workstations, not all, the client installation hangs and I am forced to use the Task Manager to terminate the install. At that point, I will reboot the workstation and attempt to install the new client. It does install without any error messages. It will appear in the tray momentarily then disappear. If I try to manually start the client I get the following error message:
All of the systems are either Windows 7 Pro 64bit, or Windows 10 Pro 64bit.
Any suggestions??
Thanks,
Mike
