Problem with urbackup service on client
urbackupclientctl.service is not runnig and cant get it to run.
what should i do
or more is not there at all
One would always need a bit more information than “it`s not working” to be able to find reasons and/or solutions :thinking:
What OS are you running ?
What other services/applications are running there ?
Which version of Urbackup are you using ?
What have you tried to fix the problem until now (details!) ?
Do you have log entries you can share that show more details ?
i am running a ubuntu server
version: Ubuntu 16.04.6 LTS
services:
[ + ] acpid
[ + ] apparmor
[ + ] apport
[ + ] atd
[ - ] bootmisc.sh
[ - ] checkfs.sh
[ - ] checkroot-bootclean.sh
[ - ] checkroot.sh
[ + ] console-setup
[ + ] cron
[ - ] cryptdisks
[ - ] cryptdisks-early
[ + ] dbus
[ + ] grub-common
[ - ] hostname.sh
[ - ] hwclock.sh
[ + ] iscsid
[ - ] keyboard-setup.dpkg-bak
[ - ] killprocs
[ + ] kmod
[ - ] lvm2
[ + ] lvm2-lvmetad
[ + ] lvm2-lvmpolld
[ + ] lxcfs
[ - ] lxd
[ + ] mdadm
[ - ] mdadm-waitidle
[ - ] mountall-bootclean.sh
[ - ] mountall.sh
[ - ] mountdevsubfs.sh
[ - ] mountkernfs.sh
[ - ] mountnfs-bootclean.sh
[ - ] mountnfs.sh
[ + ] networking
[ + ] ondemand
[ + ] open-iscsi
[ - ] open-vm-tools
[ - ] plymouth
[ - ] plymouth-log
[ + ] procps
[ + ] rc.local
[ + ] resolvconf
[ - ] rsync
[ + ] rsyslog
[ - ] screen-cleanup
[ - ] sendsigs
[ + ] ssh
[ + ] udev
[ - ] umountfs
[ - ] umountnfs.sh
[ - ] umountroot
[ + ] unattended-upgrades
[ + ] urandom
urbackup version: 2.3.4
i have tried to start the urbackupclientctl service but it will not start
logs:
2019-03-29 13:45:43: ERROR: Creating snapshot of “/etc/urbackupclientctl” failed
2019-03-29 13:45:43: ERROR: Volume group “sda1” not found
2019-03-29 13:45:43: ERROR: Cannot process volume group sda1
2019-03-29 13:45:43: ERROR: Could not find LVM volume group of volume /dev/sda1
2019-03-29 13:45:43: ERROR: Creating snapshot of “urbackupclientctl” failed.
2019-03-29 13:45:43: ERROR: Cannot access path to backup: “/etc/urbackupclientctl” Errorcode: 2 - No such file or directory
2019-03-29 13:45:43: WARNING: Hint: Directory to backup ("/etc/urbackupclientctl") does not exist. It may have been deleted or renam$
2019-03-29 13:45:43: ERROR: Indexing files failed, because of error
2019-03-29 14:53:33: WARNING: Shutting down (Signal 15)
2019-04-01 10:52:38: WARNING: Shutting down (Signal 15)
2019-04-01 12:45:04: WARNING: Shutting down (Signal 15)
2019-04-01 12:50:08: WARNING: Shutting down (Signal 15)
Well does this directory exist? And does the urbackup service user have rights to access it?
Can you run the shell command ‘lsblk’ and post the output? This will list all block devices.
Also, can you run the commands pvdisplay and vgdisplay and post the output? This will list all physical volumes and all volume groups.
