Hi
I’ve installed UrBackup server in a 2008 Server with two NICs, 172.26.1.xxx and 192.168.1.xxx, the clients in 172.26.1.xxx works ok, but the clients in 192.168.1.xxx does not works, I can see the PCs with ping, view shared folder and any other tasks, but the only UrBackup client in that side of the lan (Win7) does not reach the server. I’ve disable both firewalls but the issue still is there.
How can I check the conectivity between clients and server? Also, the server does not perform a cleanup, is there any way to force it?
Regards
