We are testing a new Server 2019 Hyper-V setup with ReFS and Dedup enabled on the VM storage. We have installed the commercial client version for Hyper-V. Full image backups work fine but we get error on incremental: “Exchanging data with client during image backup preparation failed. Connection to client broke”
Client: Server 2019 ReFS/Dedup. Version: 2.2.19-hyperv
Server: Server 2019 ReFS/Dedup. Version: 2.4.12
Here are the debug output from the client:
2020-03-02 20:35:06: Device D:\ isn’t NTFS formatted
2020-03-02 20:35:06: rc=0 hasError=true state=0
2020-03-02 20:35:06: Script “C:\Program Files\UrBackup\preimagebackup.bat” does not exist
2020-03-02 20:35:06: Creating shadowcopy of “hyperv://DHCP01/IDE:0:0”…
2020-03-02 20:35:06: FileSrv: Info: Window size=131072
2020-03-02 20:35:06: FileSrv: Received data…
2020-03-02 20:35:06: FileSrv: Received a Packet.
2020-03-02 20:35:06: FileSrv: Sending file (normal) urbackup/mbr_data_DHCP01–IDE_0_0.zip.err metadata_id=0
2020-03-02 20:35:06: FileSrv: Mapped name: C:\Program Files\UrBackup\urbackup\data\mbr_data_DHCP01–IDE_0_0.zip.err
2020-03-02 20:35:06: FileSrv: Could not open file \?\C:\Program Files\UrBackup\urbackup\data\mbr_data_DHCP01–IDE_0_0.zip.err. The system cannot find the file specified. (code: 2)
2020-03-02 20:35:06: Received flush.
2020-03-02 20:35:06: FileSrv: Sending file (normal) urbackup/mbr_data_DHCP01–IDE_0_0.zip metadata_id=0
2020-03-02 20:35:06: FileSrv: Could not open file \?\C:\Program Files\UrBackup\urbackup\data\mbr_data_DHCP01–IDE_0_0.zip. The system cannot find the file specified. (code: 2)
2020-03-02 20:35:07: FileSrv: Received data…
2020-03-02 20:35:07: FileSrv: Received a Packet.
2020-03-02 20:35:07: FileSrv: Sending file (normal) urbackup/mbr_data_DHCP01–IDE_0_0.zip metadata_id=0
2020-03-02 20:35:07: FileSrv: Mapped name: C:\Program Files\UrBackup\urbackup\data\mbr_data_DHCP01–IDE_0_0.zip
2020-03-02 20:35:07: FileSrv: Could not open file \?\C:\Program Files\UrBackup\urbackup\data\mbr_data_DHCP01–IDE_0_0.zip. The system cannot find the file specified. (code: 2)
2020-03-02 20:35:07: Received flush.
2020-03-02 20:35:08: FileSrv: Received data…
2020-03-02 20:35:08: FileSrv: Received a Packet.
2020-03-02 20:35:08: FileSrv: Sending file (normal) urbackup/mbr_data_DHCP01–IDE_0_0.zip metadata_id=0
2020-03-02 20:35:08: FileSrv: Mapped name: C:\Program Files\UrBackup\urbackup\data\mbr_data_DHCP01–IDE_0_0.zip
2020-03-02 20:35:08: FileSrv: Could not open file \?\C:\Program Files\UrBackup\urbackup\data\mbr_data_DHCP01–IDE_0_0.zip. The system cannot find the file specified. (code: 2)
2020-03-02 20:35:08: Received flush.
2020-03-02 20:35:09: FileSrv: Received data…
2020-03-02 20:35:09: FileSrv: Received a Packet.
2020-03-02 20:35:09: FileSrv: Sending file (normal) urbackup/mbr_data_DHCP01–IDE_0_0.zip metadata_id=0
2020-03-02 20:35:09: FileSrv: Mapped name: C:\Program Files\UrBackup\urbackup\data\mbr_data_DHCP01–IDE_0_0.zip
2020-03-02 20:35:09: FileSrv: Could not open file \?\C:\Program Files\UrBackup\urbackup\data\mbr_data_DHCP01–IDE_0_0.zip. The system cannot find the file specified. (code: 2)
2020-03-02 20:35:09: Received flush.
2020-03-02 20:35:09: FileSrv: Sending file (normal) urbackup/mbr_data_DHCP01–IDE_0_0.zip.err metadata_id=0
2020-03-02 20:35:09: FileSrv: Mapped name: C:\Program Files\UrBackup\urbackup\data\mbr_data_DHCP01–IDE_0_0.zip.err
2020-03-02 20:35:09: FileSrv: Could not open file \?\C:\Program Files\UrBackup\urbackup\data\mbr_data_DHCP01–IDE_0_0.zip.err. The system cannot find the file specified. (code: 2)
2020-03-02 20:35:11: done.
2020-03-02 20:35:13: Zeroing image hash data of volume hyperv://DHCP01/IDE:0:0…
2020-03-02 20:35:13: Zeroed 281 MB
2020-03-02 20:35:13: Hyper-V save_id 13
2020-03-02 20:35:16: ClientService cmd: #ILPYeoZRKxF97gGPzqA4l#2PING RUNNING pc_done=0&status_id=96&speed_bpms=0&total_bytes=-1&done_bytes=0&paused_fb=1#token=RhQbcOy5xZ7DaiSU6R0u4
2020-03-02 20:35:21: ClientService cmd: STATUS#pw=taPcpD07RxCEgvhVI5T8VcyJB0hwHw
2020-03-02 20:35:25: ClientService cmd: PONG
2020-03-02 20:35:26: ClientService cmd: #ILPYeoZRKxF97gGPzqA4l#2PING RUNNING pc_done=0&status_id=96&speed_bpms=0&total_bytes=-1&done_bytes=0&paused_fb=1#token=RhQbcOy5xZ7DaiSU6R0u4
2020-03-02 20:35:29: FileSrv: Received data…
2020-03-02 20:35:29: FileSrv: Received a Packet.
2020-03-02 20:35:29: FileSrv: Sending file (normal) urbackup/mbr_data_DHCP01–IDE_0_0.zip metadata_id=0
2020-03-02 20:35:29: FileSrv: Mapped name: C:\Program Files\UrBackup\urbackup\data\mbr_data_DHCP01–IDE_0_0.zip
2020-03-02 20:35:29: FileSrv: Reading last file part
2020-03-02 20:35:29: FileSrv: Info: File End
2020-03-02 20:35:29: FileSrv: Closed file.
2020-03-02 20:35:29: Received flush.
2020-03-02 20:35:29: FileSrv: Sending file (normal) urbackup/mbr_data_DHCP01–IDE_0_0.zip.save_id metadata_id=0
2020-03-02 20:35:29: FileSrv: Mapped name: C:\Program Files\UrBackup\urbackup\data\mbr_data_DHCP01–IDE_0_0.zip.save_id
2020-03-02 20:35:29: FileSrv: Recv Error in RecvMessage
2020-03-02 20:35:29: FileSrv: Deleting Memory…
2020-03-02 20:35:29: FileSrv: done.
2020-03-02 20:35:29: ClientService cmd: #ILPYeoZRKxF97gGPzqA4l#INCR IMAGE letter=IDE:0:0&hashsize=7290912&token=RhQbcOy5xZ7DaiSU6R0u4&checksum=1&bitmap=1&clientsubname=DHCP01&status_id=96&running_jobs=0&shadowid=13&zero_skipped=1&cbitmapsize=3645484
2020-03-02 20:35:31: ClientService cmd: STATUS#pw=taPcpD07RxCEgvhVI5T8VcyJB0hwHw
2020-03-02 20:35:36: FileSrv: ClientThread deleted. 1024 KB Memory freed.
2020-03-02 20:35:36: ClientService cmd: #ILPYeoZRKxF97gGPzqA4l#2PING RUNNING pc_done=0&status_id=96&speed_bpms=0&total_bytes=-1&done_bytes=0&paused_fb=1#token=RhQbcOy5xZ7DaiSU6R0u4
2020-03-02 20:35:46: ClientService cmd: #ILPYeoZRKxF97gGPzqA4l#2PING RUNNING pc_done=0&status_id=96&speed_bpms=0&total_bytes=-1&done_bytes=0&paused_fb=1#token=RhQbcOy5xZ7DaiSU6R0u4
2020-03-02 20:35:56: ClientService cmd: #ILPYeoZRKxF97gGPzqA4l#2PING RUNNING pc_done=0&status_id=96&speed_bpms=0&total_bytes=-1&done_bytes=0&paused_fb=1#token=RhQbcOy5xZ7DaiSU6R0u4
2020-03-02 20:36:06: ClientService cmd: #ILPYeoZRKxF97gGPzqA4l#2PING RUNNING pc_done=0&status_id=96&speed_bpms=0&total_bytes=-1&done_bytes=0&paused_fb=1#token=RhQbcOy5xZ7DaiSU6R0u4
2020-03-02 20:36:16: ClientService cmd: #ILPYeoZRKxF97gGPzqA4l#2PING RUNNING pc_done=0&status_id=96&speed_bpms=0&total_bytes=-1&done_bytes=0&paused_fb=1#token=RhQbcOy5xZ7DaiSU6R0u4
2020-03-02 20:36:19: ClientService cmd: #ILPYeoZRKxF97gGPzqA4l#2LOGDATA 1583177778 0-1583177706-Starting unscheduled incremental image backup of volume “IDE:0:0”…
0-1583177706-Basing image backup on last full image backup
0-1583177706-Loading ZIP metadata from urbackup/mbr_data_DHCP01–IDE_0_0.zip
0-1583177706-VM22[DHCP01]: Loading MBR zip file…
0-1583177729-VM22[DHCP01]: Loaded MBR zip file (14.2832 KB)
2-1583177778-Exchanging data with client during image backup preparation failed. Connection to client broke.
0-1583177778-Time taken for backing up client VM22[DHCP01]: 1m 12s
2-1583177778-Backup failed
Any ideas?
Regards
Jens
