I recently added a new client which showed up as a generic name “LAPTOP-7I21R610” before I could put a more descriptive name in its “client name” setting. It never showed up under that descriptive client name, so I tried putting the same descriptive name in its “Additional virtual sub client names” setting. This didn’t work as I was hoping and then started backing up (both image and file backups) the same client system twice, with a new name: “LAPTOP-7I21R610[Hannah's”.
I don’t see any ability to remove or rename clients from the server’s web user interface. Obviously I’d like to only back the client up once and to rename it to the simple descriptive name if possible. Aside from doing some manual editing in the various backup files to try to achieve this, any ideas about how I could do that?
Thanks for any thoughts or suggestions you may have!
