Server: UrBackup 2.4.12, debian 10.3 64bit / Linux 4.19.0-8-amd64);
Storage file system: btrfs.
Issue (Bug):
Web interface unreachable after mount raw image from web.
Mount image from web;
Web interface becomes unreachable;
Restart UrBackup service;
Mount same image again from web;
Now web interface works fine, but we have an error:
Mounting image failed. Please see server log file for details.
Guestmount... -
Reload web page with this image backup;
It’s fine! Now we see files which in the mounted image.
As far as I understand this is due to error:
Apr 22 21:54:24 urbackupsrv kernel: [855598.905596] mnt image[31818]: segfault at 7f54945990ce ip 0000000000af171b sp 00007f54737fc140 error 6 in urbackupsrv[400000+97d000]
Apr 22 21:54:24 urbackupsrv kernel: [855598.905785] Code: 8d 3c 28 75 3a 0f b6 06 48 8d 1d 40 7c 50 00 88 07 49 8b 07 48 8d 50 e8 48 39 da 74 8d 66 90 c7 40 f8 00 00 00 00 4c 89 60 e8 <42> c6 04 20 00 48 83 c4 28 5b 5d 41 5c 41 5d 41 5e 41 5f c3 90 48
The process of installing image mount support:
# apt-get install libguestfs-tools qemu-utils
# libguestfs-test-tool
===== TEST FINISHED OK =====
# urbackup_mount_helper test
MOUNT TEST OK
# reboot
Full report:
Last log strings before (/var/log/urbackup.log):
2020-04-22 20:52:06: ERROR: Error while downloading version info from http://update.urbackup.org/2.4.x/version_linux.txt: Couldn't connect to server(ec=7), Failed to connect to update.urbackup.org port 80: Connection timed out
2020-04-22 20:52:37: ERROR: Error downloading server version information: Couldn't connect to server(ec=7), Failed to connect to update.urbackup.org port 80: Connection timed out
2020-04-22 20:53:09: ERROR: Error downloading dataplan database: Couldn't connect to server(ec=7), Failed to connect to update.urbackup.org port 80: Connection timed out
Mount image.
Web interface becomes unreachable.
I checked log (/var/log/urbackup.log), nothing was changed.
Syslog:
Despite the fact that the syslog error is “mnt image [31818]: segfault”, the image has been successfully mounted.
# df -h
Filesystem Size Used Avail Use% Mounted on
udev 981M 0 981M 0% /dev
tmpfs 200M 18M 182M 10% /run
/dev/mapper/debian10test--vg-root 18G 4.1G 13G 25% /
tmpfs 998M 0 998M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 998M 0 998M 0% /sys/fs/cgroup
/dev/sda1 236M 87M 138M 39% /boot
/dev/mapper/vgurbackup-lvurbackup1 190G 109G 79G 58% /media/BACKUP/urbackup
tmpfs 200M 0 200M 0% /run/user/0
/dev/fuse 70G 23G 47G 33% /media/BACKUP/urbackup/UpBackupPC1/200229-0010_Image_C_mnt0
At the same time, the urbackupsrv service is active.
# systemctl status urbackupsrv
urbackupsrv.service - LSB: Server for doing backups
Loaded: loaded (/etc/init.d/urbackupsrv; generated)
Active: active (running) since Wed 2020-04-22 20:51:00 MSK; 1h 17min ago
After restart service the web interface starts working.
systemctl restart urbackupsrv
After restarting the service, the image in df -h is no longer mounted.
# df -h
Syslog:
Apr 22 22:11:34 urbackupsrv systemd[1]: Stopping LSB: Server for doing backups...
Apr 22 22:11:34 urbackupsrv systemd[1]: urbackupsrv.service: Succeeded.
Apr 22 22:11:34 urbackupsrv systemd[1]: Stopped LSB: Server for doing backups.
Apr 22 22:11:34 urbackupsrv systemd[1]: urbackupsrv.service: Found left-over process 1296 (qemu-system-x86) in control group while starting unit. Ignoring.
Apr 22 22:11:34 urbackupsrv systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
Apr 22 22:11:34 urbackupsrv systemd[1]: urbackupsrv.service: Found left-over process 1309 (guestmount) in control group while starting unit. Ignoring.
Apr 22 22:11:34 urbackupsrv systemd[1]: Starting LSB: Server for doing backups...
Apr 22 22:11:34 urbackupsrv systemd[1]: Started LSB: Server for doing backups.
Apr 22 22:11:36 urbackupsrv systemd[1779]: media-BACKUP-urbackup-UpBackupPC1-200229\x2d0010_Image_C_mnt0.mount: Succeeded.
Apr 22 22:11:36 urbackupsrv systemd[1]: media-BACKUP-urbackup-UpBackupPC1-200229\x2d0010_Image_C_mnt0.mount: Succeeded.
Try mount this image again.
In that time web interface works fine, but we have an error:
Guestmount...
Check df -h
# df -h
As we see the image mounted successfully.
Goto previous page
Then open this image backup again
Now we see files in the mounted image.
UrBackup log:
2020-04-22 22:11:36: ERROR: Image mounting failed: Mountpoint: /media/BACKUP/urbackup/Win7x64-Test1/200422-2034_Image_C_mnt0
Guestunmount...
guestunmount: /media/BACKUP/urbackup/Win7x64-Test1/200422-2034_Image_C_mnt0 is not mounted: fusermount: entry for /media/BACKUP/urbackup/Win7x64-Test1/200422-2034_Image_C_mnt0 not found in /etc/mtab
Unmounting "/media/BACKUP/urbackup/Win7x64-Test1/200422-2034_Image_C_mnt0" failed.
2020-04-22 22:11:36: ERROR: Unmounting image backup id 8 path "/media/BACKUP/urbackup/Win7x64-Test1/200422-2034_Image_C/Image_C_200422-2034.raw" mounted 23m 39s ago failed: Mountpoint: /media/BACKUP/urbackup/Win7x64-Test1/200422-2034_Image_C_mnt0
Guestunmount...
Syslog:
kern.log:
Apr 22 20:45:13 urbackupsrv kernel: [851448.479656] loop: module loaded
Apr 22 20:45:23 urbackupsrv kernel: [851458.389112] fuse init (API version 7.27)
Apr 22 20:45:23 urbackupsrv kernel: [851458.395518] mnt image[28547]: segfault at 7fea725950ce ip 0000000000af171b sp 00007feaccff7140 error 6 in urbackupsrv[400000+97d000]
Apr 22 20:45:23 urbackupsrv kernel: [851458.395523] Code: 8d 3c 28 75 3a 0f b6 06 48 8d 1d 40 7c 50 00 88 07 49 8b 07 48 8d 50 e8 48 39 da 74 8d 66 90 c7 40 f8 00 00 00 00 4c 89 60 e8 <42> c6 04 20 00 48 83 c4 28 5b 5d 41 5c 41 5d 41 5e 41 5f c3 90 48
Full logs attached!
logs.zip (8.8 KB)
