Server 2.1.19 Installed on windows, Default Configuration
i got incremental file backup and when trying to “Download folder as ZIP” i get emty archive, downloading file by file is working fine, just when i want to download whole directory as a zip it generate empty zip file (22kb size which is strange)
If you need some additional informations im glad to send it to you because this software is awesome : )
I think it was fixed using some other library
But there s some limiation in the zip file format that prevets it from getting to big and/or contain too much files.
You can start a restoration from the client (urbackupctl --help and look for the options and/or manual)
@orogor
directory isnt big enough for this case (its 2 files, 1mb overall
When trying to download directory on logs i see this
2017-06-12 14:51:37: ERROR: Error getting symlink target of “FilePath\file.xlsx”. Code 0
2017-06-12 14:51:37: ERROR: Error getting symlink target of “FilePath\file2.xlsx”. Code 0
