I might’ve found a bug, running Urbackup 1.1 on Ubuntu 12.10 (server side) Urbackup 1.1.1 on Ubuntu 12.10 (client side), Default directories to backup:
C:\Users;C:\Documents and Settings;G:\Backup;/etc;/opt;/home;/root;
All appears well on my Windows 7 boxes however on my Linux boxes etc and opt backup fine but /home/* and /root/* are not backed up.
Any ideas? Nothing obvious in /var/log/urbackup_client.log and nothing obvious on the server side.
After some aggressive (remove the client from the server) and remove the agent on the client side with a lot of rm -rf etc this seems to be working again. However I’ve not got this error for all the affected Linux clients:
During my re-compiling I also noticed in the packaged: /etc/init.d/urbackup_client
DAEMON=$PREFIX/bin/start_urbackup_client # Introduce the server’s location here
DAEMON_REAL=$PREFIX/bin/urbackup_client
While the default compile behavior is /usr/local/sbin/ so I set things as follows:
DAEMON=$PREFIX/sbin/start_urbackup_client # Introduce the server’s location here
DAEMON_REAL=$PREFIX/sbin/urbackup_client
Being awkward I also set my base dir to /opt/urbackup/ at compile time, as such: sbin/start_urbackup_client needed some work as well to change the working directory. Maybe there could be some work done as part of the configure to make this a bit nicer if you’re not sticking to the default install?
