We are having the same sort of discussion internally now as well. Basically deciding between iSCSI and direct attached SAS. Likely we’d use ZFS in either implementation (per the documentation Lin notes above).
Also linforpros, I don’t know what your network architecture is like that necessitates 4 backup servers. Have you considered perhaps having one backup server with direct attached storage and then bonded multiple 1Gb ethernet to service your clients? From what I can tell in reviewing the documentation strategic use of a few SSDs for temporary file buffers and/or in conjunction with a ZFS SLOG.
I would think some good questions to ask which could inform an answer would be:
How many clients do you have?
How much initial data do you have?
What is the rate of change in your data (mostly office productivity files or is there lots of big research data)?
How much data might be deduplicated (e.g. are you backing up full drives of the same machines)?
How compressible is your data (e.g. text vs video)?
How long do you need to keep (retain) the data?
Do you need both disk image and file backups?
Do you need off-site storage?
What is your network topology like? (gigabit ethernet? mostly remote clients over the internet?)
With all of those answered I’d imagine you could come up with a pretty good sense of what kind of system you would want to put into place.
I am sorry, I was offline for some days. Please find the following:
Ans: Nearly 100 clients
Ans: Around 300 GB
Ans: Around 150 GB
Ans: I donth think there is much dedulicated data
Ans: we do have only ms office files and outlook PST
Ans: As we are looking for keeping around 1 year. But in disk it would be around 45 days and later we write it on Tapes
Ans: At present we do only Full and Incremental file backups
Ans: Yes, but we manage with Tapes
Ans: 1 Gig
I’m making the assumption here that we are talking about ~ 30GB per client with ~ 15GB per client per year. So approx 450GB/year. So lets go ahead and say 1TB per yer. Given that you are going to retain for 45 days on disk you have a lot of options. It sounds like you wouldn’t need to plan for more than 4TB of raw storage over a 4 year life-cycle on a device.
Given that there are any number of devices you might purchase to meet that need here’s an idea of what might work. (note that I have no relationship with this company, they just have an easy interface for configuring servers).
The configuration below paired with Ubuntu and ZFS (which can take advantage of the SSDs for caching) is at least a good place to start. Note that UrBackup can also take advantage of storing temp files on an SSD.
