Current behaviour: the Restore button only appears if ServerStatus::canRestore() is true, meaning the client is online, its RESTORE mode isn’t disabled, and (with file access tokens) allow_file_restore is on. If any of those fail, the button simply isn’t there. Linux clients ship with RESTORE=disabled in /etc/default/urbackupclient, so on a headless box the first experience is a missing button and no hint why.
Proposal (no change to the security model):
Have the server tell the web UI why restore is unavailable. It already knows, because the client reports its mode during capability exchange. So return a reason alongside can_restore: client offline / restores disabled on the client / file restore disabled in server settings.
The UI then shows a disabled Restore button with a short explanation, e.g. “Restores are disabled on this client. Set RESTORE=server-confirms in /etc/default/urbackupclient (Linux) to allow restores started from the server.”
Optionally, a separate and smaller follow-up: have the Linux installer ask whether to enable server-confirms, defaulting to the current disabled.
The server still can’t change the client’s restore mode, so it stays the client’s decision, as Chad asked.
@uroni: is that acceptable, and do you prefer the wording or the installer prompt handled differently? I’d start with 1 and 2.
and then only as non-recommended option saying that the button can be enabled via setting server-confirms.
Don’t like asking in the installer (too many questions might be problematic) – maybe it can be a command line option or something to configure on the server for downloaded clients.
When a client is online but restores aren’t enabled, instead of just hiding the Restore button, the file browser shows the command for the backup and folder you’re looking at, e.g. urbackupclientctl restore-start -b 34 -d "foo/bar", with -v <name> added for virtual clients, and a note that it removes files not in the backup unless -n is added (same as the web restore).
Below that, as the non-recommended alternative: the Restore button can be enabled by setting RESTORE=server-confirms on the client.
For the installer, agreed, no extra question. I’d look at a server setting for the Linux client installers downloaded from the web interface, so they come preconfigured with server-confirms. Unless you’d prefer a command-line option to the install script instead?
I’ve implemented the command hint (when a client is online but has restores disabled, the file browser shows urbackupclientctl restore-start -b 34 -d ‘foo/bar’ for the folder you’re in, with server-confirms mentioned as the non-recommended alternative), and tested it against a real 2.5.x Linux client.
One problem came up that I’d like your opinion on before sending it. The restore works, but only for backups made after root has run urbackupclientctl at least once. The Linux client only creates access tokens for users with uid >= UID_MIN, and root only gets one when it first uses urbackupclientctl. A client-started restore checks the requesting user’s tokens against the ones stored in the backup, so for older backups root gets “No permissions to create files” and the restore fails. In my test, the backup made before root’s token existed failed and the next one restored fine.
On a fresh headless server nobody has usually run urbackupclientctl as root before they need a restore, so the hint would mostly lead to “Restore failed”.
Options I see:
Always create a token for root on the client (small change, but it only helps backups made after the update).
Treat root as allowed in the restore permission check on the client, since root can write everything anyway.
Keep the client as is and mention the limitation in the hint.
Which would you prefer? I’d lean towards 2, possibly together with 1. Since it’s a feature, I’ll send it against 2.6.x once that’s pushed.
