Added my /home for backup and i can t complete it, the server process crashes, the web ui too.
[sam. mai 27 22:58:56 2017] phash load[23644]: segfault at 50 ip 0000000000572397 sp 00007feb857f9a70 error 4 in urbackupsrv[400000+900000]
[sam. mai 27 23:16:32 2017] phash load[10286]: segfault at f ip 000000000000000f sp 00007f1c9dffaab8 error 14 in urbackupsrv[400000+900000]
[dim. mai 28 01:29:46 2017] phash load[13287]: segfault at 45 ip 0000000000000045 sp 00007f8c3b7fdab8 error 14 in urbackupsrv[400000+900000]
06/06/17 16:27 DEBUG No old file for “libgcc_s.so” (1)
06/06/17 16:27 DEBUG GT: File “colormap-remap” not found via hash. Loading file…
06/06/17 16:27 DEBUG GT: File “colorxhtml.py” not found via hash. Loading file…
06/06/17 16:28 DEBUG Loading “.symlink_/usr/lib/gcc/x86_64-linux-gnu/6/cc1”. 75% finished 16.0551 MB/21.1808 MB at 955.664 KBit/s
server backtrace :
2017-06-06 16:28:14: Loading “.symlink_/usr/lib/gcc/x86_64-linux-gnu/6/cc1”. 75% finished 16.0551 MB/21.1808 MB at 955.664 KBit/s
Thread 8 “urbackupsrv” received signal SIGPIPE, Broken pipe.
[Switching to Thread 0x7fffd77fe700 (LWP 14842)]
0x00007ffff6de24bd in write () at …/sysdeps/unix/syscall-template.S:84
84 …/sysdeps/unix/syscall-template.S: No such file or directory.
(gdb)
(gdb) backtrace #0 0x00007ffff6de24bd in write () at …/sysdeps/unix/syscall-template.S:84 #1 0x00007ffff601fb35 in ?? () from /lib/x86_64-linux-gnu/libcrypto.so.1.0.0 #2 0x00007ffff601db5c in BIO_write () from /lib/x86_64-linux-gnu/libcrypto.so.1.0.0 #3 0x00007ffff6376bf2 in ?? () from /lib/x86_64-linux-gnu/libssl.so.1.0.0 #4 0x00007ffff6378e13 in ?? () from /lib/x86_64-linux-gnu/libssl.so.1.0.0 #5 0x00007ffff6374a22 in ?? () from /lib/x86_64-linux-gnu/libssl.so.1.0.0 #6 0x00007ffff7bbb4c3 in ?? () from /usr/lib/x86_64-linux-gnu/libcurl.so.4 #7 0x00007ffff7b896e7 in ?? () from /usr/lib/x86_64-linux-gnu/libcurl.so.4 #8 0x00007ffff7b8a0fa in ?? () from /usr/lib/x86_64-linux-gnu/libcurl.so.4 #9 0x00007ffff7b9e5d6 in ?? () from /usr/lib/x86_64-linux-gnu/libcurl.so.4 #10 0x00007ffff7b9eeed in curl_multi_perform () from /usr/lib/x86_64-linux-gnu/libcurl.so.4 #11 0x00007ffff7b9594b in curl_easy_perform () from /usr/lib/x86_64-linux-gnu/libcurl.so.4 #12 0x00000000008c70ce in UrlFactory::sendMail(MailServer const&, std::vector<std::string, std::allocatorstd::string > const&, std::string const&, std::string const&, std::string*) () #13 0x000000000088307f in Mailer::operator()() () #14 0x000000000042ae95 in thread_helper_f(void*) () #15 0x00007ffff6dd96ba in start_thread (arg=0x7fffd77fe700) at pthread_create.c:333 #16 0x00007ffff6b0f82d in clone () at …/sysdeps/unix/sysv/linux/x86_64/clone.S:109
(gdb)
