Hello everyone, I just use urbackup to save the data of my servers (windows server 2012 r2) of the company I work for, just 5 days after the installation of the system, I have already exhausted the storage space (1TB), my question is this:
How can I make the system understand that it must overwrite the oldest backups? Otherwise, once the storage space is finished, all backups are blocked.
How can I solve?
Thank you.
Overwrite old backups
aquils
#1
MK05
#5
You can goto settings and change the minimum and maximum number of Full and INC backup to have to some lesser value. This should be done for both FileSystem and Image backup.
If you have different configuration for different clients, then change the minimum and maximum values for each client.
Then run the remove-unknown.bat file.
