The icon for Urbackup shows twice with OSX clients.
I did think maybe it was an issue that would be resolved in 2.0.31 but it’s the same.
The solution is to remove Urbackup from the login items in System preferences and Users. After a reboot the icon shows just once and the backup functions without issue.
Not a bit deal but just so you know for the next revision.
