I have installed and removed 2.0.36 multiple times but can’t seem to get the GUI working.
I will now attempt to update the OSX version and see if the problem goes away.
Strange though, I have many OSX systems running without a hitch.
10.7 isn’t supported either. I’d say at least upgrade to 10.11, otherwise you won’t get security updates. And if you don’t want to upgrade all the time use another OS
