OS X Client 2.0.34 & access_backups_shell_mui.txt
Hi!
I’ve noticed that in /Application folder, where is located ‘UrBackup Client.app’ shows up text file named ‘access_backups_shell_mui.txt’ which contains ‘&Access/restore backups’.
Is there a way to get rid of this text file from /Applications (it is recreated each time client is loaded)? If it is mandatory, maybe set another location because /Applications folder isn’t quite right place to keep such items.
Thank you
Bartosz Iljaszewicz
Will do. Thanks for the hint!
