Orphan process on Client side
Server 1.4, Client 1.4, Microsoftr Windows Serverr 2008 Standard Service Pack 2 (build 6002), 32-bit
  1. On a client when i for example open settings window and close it - some process is created but do not exit after window exit
  2. When i exit Client from tray processes from 1. do not close
  3. When i open new Client it is the same
Could you be so kind and also answer my question from Restore client config after station failure issue ?!
Thanks for the hint! Will try to fix this with the next release.
