I have a problem with the mbr restore from a usb disk.
I copied the full image backup folder in the usb disk.
I booted with the urbackup livecd (version 2.0.1)and I executed these commands:
- /root/urbackuprestoreclient --restore-mbr path/*.vhd.mbr -o /dev/sda
- partprobe /dev/sda
but the Partitions table are not re-read.
The command “fdisk -l /dev/sda” has not reported nothing and "sfdisk " has reported the partitions disk.
In /dev folder there is only the device “sda” without partitions.
How do I fix it?
Thank you.
Best Regards
