With every file backup I get the following warnings:
2023-01-27 08:01:41(warning): Writer NTDS has failure state VSS_WS_FAILED_AT_POST_SNAPSHOT with error VSS_E_WRITERERROR_NONRETRYABLE. UrBackup will continue with the backup but the associated data may not be consistent.
2023-01-27 08:01:41(warning): Writer is in error state during snapshot creation. Writer data may not be consistent. This means the files open by this application (e.g. databases) will be backed up in a crash consistent state instead of a properly shutdown state. Properly written applications can recover from system crashes or power failures.
Since I get no info which files might be affected I cannot check if there is any problem.
How would I go about removing the cause for the warning? Or if the cause cannot be removed, how would I check if the data is intact?
Thanks in advance for your replies and best regards.
