Add new linux client, start first full file backup.
At the status page: Completed with issues
At the end of log: Backup succeeded
At the log Warning: Not all folder metadata could be applied. Metadata was inconsistent.
Should I be worried about it?
What does it mean?
Server: Debian 10, UrBackup server 2.4.13;
Client: Debian 10, UrBackup client 2.4.10;
Full log:
Level | Time | Message |
Info | 22.07.2020 7:00 | Starting scheduled full file backup… |
Info | 22.07.2020 7:07 | Starting prefilebackup script |
Info | 22.07.2020 7:07 | run: /usr/local/mgr5/sbin/mgrctl -l |
Info | 22.07.2020 7:07 | run: systemctl stop apache2.service ihttpd.service mariadb.service nginx.service php-fpm54.service php-fpm56.service proftpd.service |
Info | 22.07.2020 7:07 | prefilebackup succeeded |
Info | 22.07.2020 7:07 | Using default stripesize 64.00 KiB. |
Info | 22.07.2020 7:07 | Logical volume “urbackup_snap_c300bd8986ce652bd34b9d2f1a218d0647c23390fa63f492” created. |
Info | 22.07.2020 7:07 | Indexing of “rootfs” done. 225172 filesystem lookups 0 db lookups and 0 db updates |
Info | 22.07.2020 7:07 | Backing up “boot” without snapshot. |
Info | 22.07.2020 7:07 | Indexing of “boot” done. 6 filesystem lookups 0 db lookups and 0 db updates |
Info | 22.07.2020 7:07 | Starting postfileindex script (normally starts after indexing and snapshot creation) |
Info | 22.07.2020 7:07 | run: systemctl start apache2.service ihttpd.service mariadb.service nginx.service php-fpm54.service php-fpm56.service proftpd.service |
Info | 22.07.2020 7:07 | run: /usr/local/mgr5/sbin/mgrctl -u |
Info | 22.07.2020 7:07 | postfileindex succeeded |
Info | 22.07.2020 7:07 | ilogy-isp1: Loading file list… |
Info | 22.07.2020 7:07 | ilogy-isp1: Started loading files… |
Info | 22.07.2020 8:14 | Referencing snapshot on “ilogy-isp1” for path “boot” failed: FAILED |
Info | 22.07.2020 8:14 | Waiting for file transfers… |
Info | 22.07.2020 8:14 | mariadbdump.sql: Starting backup of MariaDB at Wed Jul 22 08:14:43 MSK 2020… |
Info | 22.07.2020 8:15 | mariadbdump.sql: Backup of MariaDB finished at Wed Jul 22 08:15:09 MSK 2020. |
Info | 22.07.2020 8:15 | Waiting for file hashing and copying threads… |
Warnings | 22.07.2020 8:16 | Not all folder metadata could be applied. Metadata was inconsistent. |
Info | 22.07.2020 8:16 | Writing new file list… |
Info | 22.07.2020 8:16 | All metadata was present |
Info | 22.07.2020 8:16 | Transferred 20.8712 GB - Average speed: 44.1884 MBit/s |
Info | 22.07.2020 8:16 | (Before compression: 30.8975 GB ratio: 1.48039) |
Info | 22.07.2020 8:16 | 11.0124 GB of files were already present on the server and did not need to be transferred |
Info | 22.07.2020 8:16 | Time taken for backing up client ilogy-isp1: 1h 15m 34s |
Info | 22.07.2020 8:16 | Backup succeeded |
