Just as a update for anyone finding this topic at a later date. I think it’s related to the exponential backoff, but I can’t be sure. The backups just arent triggered by the server. I resolved this by creating a python script to access the server through the api, check if any image backups have not run as they should have been according to their schedule + 4 hours, and then trigger a incremental or full backup, based on if the next backup is supposed to be a incremental or full backup (again, through accessing the settings). It also won’t run the backup again if it’s already running for the client and it wont start a backup if there are already 2 backups running…
This python script then runs every hour so it should solve my problems for now, whatever’s causing them…
#!/usr/bin/python
import urbackup_api
import time
import datetime
server = urbackup_api.urbackup_server("http://127.0.0.1:55414/x", "admin", "yourpasswordhere")
clients = server.get_status()
numfailed = 0
numtasks = 0
lastbackup = ""
#Logging to log file, specify path below if you want a different one.
log_file = open("/var/log/urbackup-manualsched", "a")
runningtasks = server.get_actions()
settings = server.get_global_settings()
max_fullimage_age = settings["update_freq_image_full"]
max_increimage_age = settings["update_freq_image_incr"]
max_simbackups = settings["max_sim_backups"]
diff_time = int(settings["update_freq_image_incr"]) + 14400 #max time for incremental image backup + 4 hours in seconds
#Start logging
curdate = datetime.datetime.fromtimestamp(time.time()).strftime("%x %X")
print("---------------------------------------------------", file=log_file )
print("Starting new manual image backup schedule check ({curdate}).".format(curdate=curdate ), file=log_file )
for tasks in runningtasks:
numtasks = numtasks + 1
if numtasks >= int(max_simbackups):
print("Number of already running tasks: {numtasks}, NOT starting more backups.".format(numtasks=numtasks ), file=log_file )
else:
print("Number of already running tasks: {numtasks}, going to start queueing backups.".format(numtasks=numtasks ), file=log_file )
print("Performing check on all clients...", file=log_file )
for client in clients:
clientbackuprunning = 0
if client["lastbackup_image"]=="-" or client["lastbackup_image"] < time.time() - diff_time:
if client["online"] != False and client["lastbackup_image"]!="-" and client["lastbackup_image"]!=0:
lastbackup = datetime.datetime.fromtimestamp(client["lastbackup_image"]).strftime("%x %X")
numfailed = numfailed + 1
#If less then the maximum amount of backup tasks are already running
if numtasks <= int(max_simbackups):
#Now to find out if a backup task is already running for this client
if tasks["name"] == client["name"]:
print("Backup is already running for {clientname}, not queueing another backup for it.".format(clientname=client["name"] ), file=log_file )
clientbackuprunning = 1
if clientbackuprunning == 0:
#Now to find out if the next backup to run is a full backup or incremental backup
backups = server.get_clientimagebackups(client["id"])
lastfullbackuptime = 0
for backup in backups:
if backup["incremental"] == 0 and backup["backuptime"] > lastfullbackuptime:
lastfullbackuptime = backup["backuptime"]
#Now to check if the maximum time for a full backup has been exceeded and the backup isnt already running
if lastfullbackuptime < time.time() - int(max_fullimage_age):
print("Starting full image backup for {clientname}.".format(clientname=client["name"] ), file=log_file )
server.start_full_image_backup(client["name"])
else:
print("Starting incremental image backup for {clientname}.".format(clientname=client["name"] ), file=log_file )
server.start_incr_image_backup(client["name"])
print("Script done executing...", file=log_file )
print("Number of image backups older then {calc_hours} hours: {numfailed}".format(numfailed=numfailed, calc_hours = diff_time / 3600 ), file=log_file )
