I would like to install the URBackup client silently on computers via our package deployment system.
To do that it should be possible to add the parameters for the silent installation like language etc…
Is it possible ?
thanks.
Verus.
Is it possible ?
thanks.
Verus.
The NSIS installer supports following arguments: http://nsis.sourceforge.net/Which_command_line_parameters_can_be_used_to_configure_installers
The lagnuage selection screen during installation only affects the installer language, nothing else.
The MSI installer probably has a silent install option as well (/? will probably show them). The MSI installer was mainly created to allow client installation via GPO, so if you use active directory that could be an option as well.
Hi.
But “msi” installer is 64Bit only. Will you be able to make 64/32Bit “msi” package?
Hmm yes. It’s work. Isn’t it easier to use the nsis installer?
Have you tried silent install builder? http://www.silentinstall.org/
