I am building a UR backup server that will have 4 NIC’s going to 4 different subnets with different IP ranges. I will connect each nic to the correct switch and set an IP. I have to backup about a hundred systems. If I just put the server Id into each client’s .txt file, will this work? OR do I setup Internet Mode? the server is local to each separate LAN, and will have a link from each NIC to that LAN.
thanks
Les
