Is there a way to have multiple instances of urbackup running on the same computer connected to different servers or shoudl that be a feature request?
You mean you want to back up to multiple servers? I thought I saw this before, so after a quick search - first paragraph here
Although this might be for older version, so take care.
To clarify I am looking to backup to a local urbackup as well as an offsite urbackup server. Does this still seem feasible with modifying the ident?
As long as you can reach the server, it should be possible. Worst case scenario you just edit the file back, nothing bad will happen. Try it out, see what happens.
So far so good. I have 2 local servers connected together. Going to try a system state and make sure everything works properly. If that works I will try the offsite with the local and see how it goes. Thanks for pointing me in the right direction.
