Is there a way to restore multiple files through the web interface without having to download each one at a time? It’d be nice to be able to select a group of files and download just that group.
how can i restore separate user data of full backup with all incremental , If after disaster i will restore all data on fresh PC
I will be honest, the only way I saw to do this was to restore a zip of the users directory and if that was too big, then to restore zips of the various sub directories (like a zip of user1/Documents, user1/Desktop, etc.) As much as I really like urbackup I ended up having to go a different direction. I do check on it though to see if any changes made will make it fit better for my organization.
You don’t have to use the WebUI. You can share your Backup directory and browse there to restore directly from the folder without having to use the WebUI.
