hello,
I configured with the ‘/’ trick to use multiple buckets in S3 storage.It doesn’t work. only the first bucket is used. how to make sure they are all used.
I sent a report from my appliance. case id is #142
Thanks in advance
hello,
Thanks in advance
Yeah, like I said in the other thread:
There is a trick to use multiple buckets (this is not well tested so avoid if possible). You can enter multiple bucket names like
bucket1/bucket2(separated by/) and it will write to the first bucket (bucket1in the example) while still reading/deleting from all of them.
There is currently a version in testing which properly shards between the buckets, so this’ll be available soon.
This is good news, I’m looking forward to this version.
Thank you
David
I have a question. I saw an update (9.19) on the multi bucket fix. My settings (9.15) are with multi bucket but only the first one is used and the others are empty.
If I do an update, will my configuration be applied correctly?
Sorry! You can access the functionality by adding a __SHARD__/ prefix to the bucket configuration.
So __SHARD__/bucket1/bucket2.
And please keep a backup of the cloud drive encryption key, just in case.
What is SHARD option ?
Causes it to write to all the buckets.
I will make this update in two days.
All I will have to do is change the bucket setting and save?
And then reboot. Yes.
Thank you very much. URBACKUP is a very good backup solution.
