hello, How can I get monitoring menu?
thank you in advance
No response,
I re-installed URBACKUP, now monitoring appears in the menu.
thanks anyway
Hi there,
just for clarification. What is meant by “monitoring”? Is it the monitoring from http://app.urbackup.com/ or is it the ““Access web server data (netdata)” in the appliance GUI or something else?
No, in the settings sub-menu just after the system
Thanks.
I just wanted to use the monitoring menu you mentioned and the result is an alert box “Sorry, an error while saving the settings occured: Device not found”. Hm …
