just saw that:
Acronis
This feature sounds like a nice feature for UB as well
just saw that:
Acronis
In my opinion that-s not really the task of a backup software.
Use the operation system tools therefore or a monitoring solution.
Unter linux it would be smartmontools. Which can also send you e-mails on problems.
Otherwise basically every monitoring solution I know about, also checks the smart status of HDDs.
It does actually does do very basic monitoring via wmic diskdrive get caption,status,statusinfo /value on Windows (looks if status is not ok). But I haven’t actually seen anyone having messages from that monitoring…
But I agree with rmm, that in general a separate tool should be used (like e.g. Zabbix).
Sure, thats not the main purpose of urbackup - but a nice extra portion of info, since the client is on every relevant pc
