Running UrBackup on Windows server, the current backup data is on D:\UrBackup but I need to replace the disk - it’s larger and space is getting low. I have mounted the new drive on a donor server (same format, the server is in the same domain so permissions should be ok) and wanted to copy over the data from the old drive to the new one. Once migrated I will simply switch out the old drive for the new one.
Have tried using robocopy on the donor server specifying the source as “\SERVER\d$\UrBackup” and the destination as D:\UrBackup with the /SL parameter to handle the links. The actual command I used was:
ROBOCOPY.exe "\\URBSRV\d$\UrBackup" D:\UrBackup /MIR /COPYALL /DCOPY:DAT /SEC /SECFIX /B /W:5 /MT:8 /ETA /V /LOG:URBSRV_D_UrBackup_Exceptions.LOG /TEE /SL
The command is the same as I have used for many other data migrations including the other data on the same drive. but apart from taking an extremely long time, I’m not convinced it’s worked because there’s a lot of errors logged:
New File 0 \\URBSRV\d$\UrBackup\FRINK\current\usr\share\man\man3\SSL_use_RSAPrivateKey.3ossl.gz
2023/10/18 10:25:01 ERROR 1463 (0x000005B7) Copying File \\URBSRV\d$\UrBackup\FRINK\current\usr\share\man\man3\SSL_use_RSAPrivateKey.3ossl.gz
The symbolic link cannot be followed because its type is disabled.
New File 0 \\URBSRV\d$\UrBackup\FRINK\current\usr\share\man\man3\SSL_use_RSAPrivateKey_ASN1.3ossl.gz
2023/10/18 10:25:01 ERROR 1463 (0x000005B7) Copying File \\URBSRV\d$\UrBackup\FRINK\current\usr\share\man\man3\SSL_use_RSAPrivateKey_ASN1.3ossl.gz
New File 0 \\URBSRV\d$\UrBackup\FRINK\current\usr\share\man\man3\SSL_use_RSAPrivateKey_file.3ossl.gz
2023/10/18 10:25:01 ERROR 1463 (0x000005B7) Copying File \\URBSRV\d$\UrBackup\FRINK\current\usr\share\man\man3\SSL_use_RSAPrivateKey_file.3ossl.gz
New File 0 \\URBSRV\d$\UrBackup\FRINK\current\usr\share\man\man3\SSL_verify_cb.3ossl.gz
2023/10/18 10:25:01 ERROR 1463 (0x000005B7) Copying File \\URBSRV\d$\UrBackup\FRINK\current\usr\share\man\man3\SSL_verify_cb.3ossl.gz
Can I ignore these or is there another better way to copy the data to the replacement drive?
