Testing with docker image i started with out the SYS_ADMIN permission so it ran a few backups with out BTRFS snapshots. when i figured this out and fixed the docker the backups failed with error could not make snapshot(not exact error) since this was a new secondary backups server i was able to just nuke the backups and start over on that one…
how ever i have another instance running on a sonology that is also on btrfs but using hardlinks 50tb using 17T of physical disk space. if there is not a way after the second server gets a safe amount of backup data i can just nuke the org one… but i would rather do a in place update to keep the older data in case it’s needed. [because of custom attributes on the sonology btrfs i was never able to rsync/btrfs send the data to another system]
if not something to warn or detect on a running server if it started with hard links and changed to btrfs.
