Boa tarde!
Queria saber se é possível migrar 1 único cliente de um servidor urbackup para outro servidor urbackup sem precisar mover todos arquivos de bancos de dados.
@Forum_Helper_bot Translate this
Here is the translation of the user’s request from Portuguese to English:
Good afternoon!
I wanted to know if it is possible to migrate a single client from one urbackup server to another urbackup server without having to move all database files.
Search
Found 2 results for 'migrate single client urbackup server status:public'
Based on the search results, it does not appear there is a direct way to migrate a single client from one UrBackup server to another without moving all the database files. The two potentially relevant topics found were:
Urbackup metaserver - This is a feature request for a meta-server that could manage and synchronize multiple UrBackup servers, but it’s not an existing capability.
Remove-unknow obliterating backup destnation after migration (Windows => Debian) - This discusses migrating an entire backup store from Windows to Linux by mounting the drives and using rsync. But it’s moving the whole backup, not a single client.
To get a more definitive answer, I would suggest searching the documentation or asking on the forums if anyone has found a way to do a single client migration. But based on these search results, it seems migrating individual clients between servers may not be directly supported without moving database files. The typical approach appears to be moving the entire backup store when changing servers.
Ok, é que eu precisava transferir um cliente específico com seu backup completo de imagem de um servidor antigo para um novo servidor, sem ter que criar um novo backup completo, isso se trataria como uma melhoria no software?
