Many errors in logs, backup failed
Hi, I’m newbie to urbackup and have some problems…
First: Server OS: CentOS7 64-bit, Urbackup server version: 2.0.33 and tried also 2.0.32, compiled from sources as the dedicated repo contains old v1.4. Client OS: Win10, Client version: 2.0.32.
Client is connecting to server (status: connected), client is “online” in the server web interface.
On server “firewalld” turned off, iptables are empty, selinux turned off.
On client “windows firewall” turned off, AV temporary disabled.
When clicking “full backup” on client, a message “Starting backup failed” appears.
Server log:
2016-09-13 15:55:25: Downloading version file…
2016-09-13 15:55:25: Downloading server version info…
2016-09-13 15:56:51: WARNING: Shutting down (Signal 15)
2016-09-13 15:56:51: Exited Loop
2016-09-13 15:56:51: Deleting at…
2016-09-13 15:56:51: Deleting SelectThreads…
2016-09-13 15:56:51: Deleting lbs…
2016-09-13 15:56:51: Shutting down plugins…
2016-09-13 15:56:51: Deleting server…
2016-09-13 15:56:51: Starting HTTP-Server on port 55414
2016-09-13 15:56:51: HTTP: Server started up successfully!
2016-09-13 15:56:51: SQLite: recovered 1 frames from WAL file /usr/local/var/urbackup/backup_server_link_journal.db-wal code: 283
2016-09-13 15:56:51: Started UrBackup…
2016-09-13 15:56:51: Removing temporary files…
2016-09-13 15:56:51: Recreating temporary folder…
2016-09-13 15:56:51: Backup destination cannot handle subvolumes and snapshots. Snapshots disabled.
2016-09-13 15:56:51: Broadcasting on interface IP xx.xx.xx.xx
2016-09-13 15:56:52: InternetService: Server started up successfully!
2016-09-13 15:56:52: UrBackup Server start up complete.
2016-09-13 15:56:52: Server started up successfully!
2016-09-13 15:56:52: Looking for old Sessions… 0 sessions
2016-09-13 15:56:52: Authentication failed in InternetServiceConnector::ReceivePackets: Token not found
2016-09-13 15:57:22: New Backupclient: pc-win10
2016-09-13 15:57:22: Socket has error: 111
2016-09-13 15:57:22: Connecting to ClientService of “pc-win10” failed: Sending Identity to client “pc-win10” failed. Retrying soon…
2016-09-13 15:59:22: Socket has error: 111
2016-09-13 15:59:22: Connecting to ClientService of “pc-win10” failed: Sending Identity to client “pc-win10” failed. Retrying soon…
I tried to google this out but with no success… any help appreciated. Thx. WS
This is probably this: https://www.urbackup.org/faq.html#ident_err
Yes, it needs to communicate this issue better…
