Is there a way to setup defaults for
- backup server address
and optional
- restore key
- fixed username
When I want to restore a client, that is in another subnet than the server, the workflow is frustrating long.
- Bootup from stick
- Wait some minutes for finishing the unskipable scan to fail
- Select “enter server address” and enter server adress with the correct port
- Enter internet restore key
- For whatever reason wait again the same amount of time like in number 2
- Enter user credetials
and finally I can select what to restore.
I really would like to automate some of these steps by setting up a configuration file on the USB stick.
Making an USB restore stick for a specific computer, that does steps 1-5 automatically and the user has just to enter the login and then select what to restore would be a nice thing.
