MacOS client 2022
Hi @Moisie
I’ve tried downgrading but it looks like its caused an issue.
I see this in the client logs
2022-06-07 13:19:09: SQLite: recovered 4613 frames from WAL file /Library/Application Support/UrBackup Client/var/urbackup/backup_client.db-wal code: 283
I’ve also attached a pic of what the menu from the icon looks like now.
Clicking access backup errors saying ‘cannot get server url’
Clicking status just says that there was an error and nothing can be backed up
hmmm actually by moving
backup_client.db backup_client.db-shm backup_client.db-wal
out of /Library/Application Support/UrBackup Client/var/urbackup the client was able to connect and has immediately resumed a backup. Hopefully it runs OK
Hi @absolution
Thanks for the feedback.
Yes - that’s normal. The SQLite database often doesn’t get cleanly closed, so you’ll see these messages. The same thing happens on the server.
I don’t yet know what determines this condition, but in my experience either waiting, or restarting the client process seems to kick it into life.
Ah good - please keep us posted! :crossed_fingers:
Unfortunately the problem has come back. The first backup started successfully (and had to be resumed a couple of times due to my Mac switching off) but new backup attempts since the first completed have failed with the usual error.
I’ve confirmed that I am indeed using client version 2.4.12 now.
Hi
Thanks for the update - but I’m out of ideas for the moment - sorry…
@absolution Maybe think about what might be different with this Mac. E.g. some firewall/security/anti-virus software is installed?
On Windows I’d say record a sysmon trace and maybe send that. On macOS the equivalent would be tracing it with dtruss perhaps. But that’s hard to use because of security reasons, so…
Thanks @uroni
This might not be Mac-related. The backup of the server itself (OS is ubuntu-server) is now struggling to backup, showing the same error.
So this could actually be related to the server itself…
The urbackup-server is just the official docker image though, so should be fairly static. I guess I could try removing it and refetching the container…
Maybe not…
My server backup did that one time 6 days ago and has been fine since. The Mac however is continuing to have the same issue.
To the best of my knowledge there’s no antivirus or firewall software installed on this Mac. The backups were completely fine until I upgraded to the latest OS. Is there anything apple might enable when upgrading to Monterey?
Alright, it looks like another client (a Windows PC client) just had the same error, so now a Windows PC, the linux server and a Mac client have had the same issue. The issue is definitely most common on the Mac client but I think there’s enough evidence that this is now related to the network or server.
Thanks for the help everyone.
Working well here thanks. Monterey 12.4 M1 mini. Looking forward to Apple Silicon native support, otherwise perfect so far! urbackup is exactly what I’ve been waiting for, Server is on a QNAP 451+
Al
I’m still unable to get this working on my Mac. I’ve been trying since the MacOS client was relaunched in 2021. Current issues continue to be
I’ve tried uninstalling, deleting all etc, var files leftover and then reinstalling.
New issue, on installation I’m prompted that Urbackup Client doesn’t have full disk access. Full disk access is granted and the only way to get rid of the prompt is to restart the computer.
Hello @mafiaboy01
Sorry to hear about the issues you’re having. Could you please fill in some details about what you’re attempting to do, and what happens when you do so?
This is a normal message, and doesn’t indicate an error. It’s how the client re-opens its database on startup.
Yes - I know about that, but haven’t yet had chance to fix it - sorry. As you say, restarting the computer appears to bypass the issue.
Is the native integration of the macOS client for the server webui already planned? I mean: download a preconfigured client, like with windows/linux? EDIT: And for autoupdate.
Regards :slight_smile:
I am trying out the macos client (2.5.x) with the latest version of urbackup server. I first installed the 2.4.x version by mistake and then uninstalled it and went to 2.5.x. Now the server is giving me a “server rejected” message. Instructions on the urbackup help site say to “Delete the server_idents.txt on the client” but I cannot find that file. Any help would be appreciated.
Hello @rdagitz
Assuming you haven’t got any configuration that you need saved on the Mac client, then your best bet is:
  • Uninstall the client from the menu bar icon
  • Delete /Library/Application Support/UrBackup Client
  • Reinstall the 2.4.x client.
Then you should be back to a blank slate.
Hello everyone !
Today, I decided to try out the macOS beta client. We already run urbackup for windows and linux and it works like a charm !
I’m facing a weird issue tho, on mac os, after installing client and giving the server settings, looking at the log and it says:
Apache2 proxy config
ProxyPass "/socket"  "ws://localhost:55414/socket"
Trying to connect to internet server "wss://backup.url/socket"
No result when looking up hostname "wss://backup.url/socket". Err 0
I guess it’s a Mac thing… with the exact same settings it works on Linux and Windows clients. (all internet clients)
Server version: 2.5.29
Client mac version: 2.5.16
macOS version: Montery 12.6.3
Anyone has faced this issue yet?
(last quick thing, locales seems to not work since the system is in French but the client stays in English)
Kind regards,
Bumpity-bumpy-bump :grin:
Any macOS veteran who could give hints on how to deeply debug this?
Kinds regards,
Hello @Kabush
Sorry for not replying on this sooner.
I’m probably not going to be any help here… I don’t have a proxy configured, and I don’t see any of the messages you’ve quoted there (though I’m running macOS client version 2.4.12). Indeed - searching the log for Trying to connect shows no results at all.
Might be worth starting a new forum thread on this - I’m not sure it’s a macOS-specific issue (despite that you’re running Linux and Windows clients successfully).
Hope that helps…
Hi there.
I’ve been using the client for awhile now and it’s been working great. Unfortunately I made the mistake of upgrading to Sonoma, and I think Apple are up to their usual tricks.
Urbackup is no longer able to read files in the Documents folder
“Error getting complete file FILEPATH Errorcode: TIMEOUT (2)”
Full Disk Access has been enabled the entire time.
Is there some new access permission I need to grant?
Thanks in advance!
Hi again.
Does anyone have any advice or suggestions for recovering urbackup Documents directory access in Sonoma?
