@uroni Found the problem (my bad…), and just submitted a PR. Might be another couple of small tweaks coming along soon too.
Done.
Updated version:
UrBackup Client 2.5.11 beta.pkg (6.0 MB)
On 10.13.6, always the same problem, segmentation error when executing urbackupclientbackend
On 10.15.7, install OK, test OK
With debug symbols: UrBackup Client 2.5.11 beta.pkg (7.1 MB)
Run with
lldb urbackupclientbackend
> run
> thread backtrace
iMac-de-BUZZZ:sbin atelier$ lldb urbackupclientbackend
(lldb) target create “urbackupclientbackend”
Current executable set to ‘urbackupclientbackend’ (x86_64).
(lldb) run
Process 2190 launched: ‘/Applications/UrBackup Client.app/Contents/MacOS sbin/urbackupclientbackend’ (x86_64)
Process 2190 stopped
- thread #1, queue = ‘com.apple.main-thread’, stop reason = EXC_BAD_ACCESS (code=1, address=0x0)
frame #0: 0x00007fff53980232 libsystem_c.dylibstrlen + 18 libsystem_c.dylibstrlen:
-> 0x7fff53980232 <+18>: pcmpeqb (%rdi), %xmm0
0x7fff53980236 <+22>: pmovmskb %xmm0, %esi
0x7fff5398023a <+26>: andq $0xf, %rcx
0x7fff5398023e <+30>: orq $-0x1, %rax
Target 0: (urbackupclientbackend) stopped.
(lldb) thread backtrace
- frame #0: 0x00007fff53980232 libsystem_c.dylib
strlen + 18 frame #1: 0x00000001000030a5 urbackupclientbackendstd::__1::char_traits::length(char const*) + 21
frame #2: 0x00000001004bb621 urbackupclientbackendstd::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >::basic_string<std::__1::nullptr_t>(char const*) + 49 frame #3: 0x00000001004a0dbd urbackupclientbackendstd::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >::basic_stringstd::__1::nullptr_t(char const*) + 29
frame #4: 0x00000001004a40a7 urbackupclientbackendmain + 567 frame #5: 0x00007fff53930015 libdyld.dylibstart + 1
frame #6: 0x00007fff53930015 libdyld.dylib`start + 1
(lldb)
Is this client compatible with UrBackup server 2.4.13? It took forever for me for it to connect to a local server, then after a couple hours it dropped the connection and wouldn’t connect at all. I couldn’t get it to work at all with an internet server.
I thought the file size is larger, so it must have debug data… but that wasn’t the case. This one should have debug data:
UrBackup Client 2.5.11 beta.pkg (6.3 MB)
It might not be.
I’d assume recommended server is 2.5.17 for this client?
Hi:
I’ve run the debug package on macOS 10.13.6, with this outcome:
admin$ lldb /Applications/UrBackup\ Client.app/Contents/MacOS/sbin/urbackupclientbackend
(lldb) target create "/Applications/UrBackup Client.app/Contents/MacOS/sbin/urbackupclientbackend"
Current executable set to '/Applications/UrBackup Client.app/Contents/MacOS/sbin/urbackupclientbackend' (x86_64).
(lldb) run
Process 1153 launched: '/Applications/UrBackup Client.app/Contents/MacOS/sbin/urbackupclientbackend' (x86_64)
Process 1153 stopped
* thread #1, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=1, address=0x0)
frame #0: 0x00007fff66e66232 libsystem_c.dylib`strlen + 18
libsystem_c.dylib`strlen:
-> 0x7fff66e66232 <+18>: pcmpeqb (%rdi), %xmm0
0x7fff66e66236 <+22>: pmovmskb %xmm0, %esi
0x7fff66e6623a <+26>: andq $0xf, %rcx
0x7fff66e6623e <+30>: orq $-0x1, %rax
* frame #0: 0x00007fff66e66232 libsystem_c.dylib`strlen + 18
frame #1: 0x00000001002c312e urbackupclientbackend`main + 942
frame #2: 0x00007fff66e16015 libdyld.dylib`start + 1
frame #3: 0x00007fff66e16015 libdyld.dylib`start + 1
For the record, I get the same behaviour on macOS 10.12.3 (backend dies with a Segmentation fault when run from Terminal) - but I know it works on macOS 10.12.6. Will investigate further and report back…
strlen() called with a NULL pointer, called at 942 bytes offset from main() start. Seems very simple to fix.
Patches welcome. Thanks!
Ok. As I do not have a Mac I ended up building a Hackintosh and managed to compile server and clients. Pull requests has been made on your GitHub repo. Problems are related to hard-coded absolute paths. App Bundles uses relative paths to access icons and all other resources.
Because of the required notarization I’m unable to test the final setup pkg.
Many thanks @Mathias_Gruber - your help here is much appreciated!
Thanks! (Non-mac users to the rescue
It’ll take a bit unfortunately till I can build a new signed pkg currently.
@uroni: Trying with the last version, this problem or similar, still happens.
I’ve back-traced the call stack:
_std::__1::char_traits<char>::length(char const*)
_std::__1::list<TCLAP::Arg*, std::__1::allocator<TCLAP::Arg*> >::push_front(TCLAP::Arg* const&)
_TCLAP::SwitchArg::combinedSwitchesMatch(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >&)
_void TCLAP::ClearContainer<std::__1::list<TCLAP::Visitor*, std::__1::allocator<TCLAP::Visitor*> > >(std::__1::list<TCLAP::Visitor*, std::__1::allocator<TCLAP::Visitor*> >&)
This hits the TCLAP library. I’ve saw that a newer version is available. Maybe updating it, could fix this.
A second back-trace, this time with input command line arguments, points to the same source:
_std::__1::vector<SCacheItem, std::__1::allocator<SCacheItem> >::max_size() const
_std::__1::vector<SCircularLogEntry, std::__1::allocator<SCircularLogEntry> >::resize(unsigned long)
_std::__1::__tree<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::__map_value_compare<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, true>, std::__1::allocator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >::erase(std::__1::__tree_const_iterator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::__tree_node<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, void*>*, long>)
Hope it helps!
I’d run it with asan to get a better error location (compile with -fsanitize=address in CPPFLAGS + LDFLAGS). Your stack trace is also missing files:lines and doesn’t make much sense…
I am running on a debug environment here and interestingly I have a crash in the std::string getSystemServerName(bool use_fqdn) method.
Specifically inside fgets. I checked docs but cannot find an error, but it is 100% reproducible. I will try a bit harder.
Aside of that, I found an error in cmdline_preprocessor.cpp @230:
if (argc > 0 &&
std::string(argv[1]) == "--internal")
The correction is argc > 1.
I think the buffer needs to be zero initialized (add = {}).
char hostname_appl[MAX_PATH + 15] = {};
and
char buf[4096] = {};
The Linux man for fgets has this
A terminating null byte (aq\0aq) is stored after the last character in the buffer.
… but I cannot see it in the macos manual…
