Lot of errors when running remove-unknown -> Resolved
Hi all,
I had an issue with my storage on freenas system, my pool goes offline. I have installed UrBackup on another pool, but the mointpoint also disappared, so some backups were written on the wrong pool. As I noticed this I have stopped the jail and copied all data manual to the normal location, but of course the database on the normal storage is not up to date anymore. So I run “urbackupsrv remove-unknown” and tried to clean broken links or something, but I know DB will not be updated so I will run some full backups this night. Nevertheless the command got errors:
root@UrBackup:/ # urbackupsrv remove-unknown
2017-12-28 00:38:22: Going to remove all unknown files and directories in the urbackup storage directory. Waiting 20 seconds…
2017-12-28 00:38:42: Shutting down all database instances…
2017-12-28 00:38:42: Opening urbackup server database…
2017-12-28 00:38:42: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:42: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:38:42: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:42: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:43: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:43: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:38:43: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:43: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:44: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:44: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:38:44: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:44: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:45: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:45: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:38:45: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:45: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:46: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:46: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:38:46: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:46: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:47: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:47: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:38:47: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:47: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file
2017-12-28 00:38:47: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:48: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:48: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:38:48: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:48: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:49: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:49: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:38:49: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:49: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:50: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:50: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:38:50: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:50: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:51: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:51: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:38:51: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:51: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:52: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:52: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:38:52: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:52: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file
2017-12-28 00:38:52: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_files.db-shm) - errorcode: 14
2017-12-28 00:38:52: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:53: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:53: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_files.db-shm) - errorcode: 14
2017-12-28 00:38:53: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:53: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:54: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:54: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_files.db-shm) - errorcode: 14
2017-12-28 00:38:54: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:54: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:55: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:55: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_files.db-shm) - errorcode: 14
2017-12-28 00:38:55: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:55: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:56: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:56: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_files.db-shm) - errorcode: 14
2017-12-28 00:38:56: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:56: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:57: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:57: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_files.db-shm) - errorcode: 14
2017-12-28 00:38:57: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:57: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file
2017-12-28 00:38:57: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:58: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:58: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_files.db-shm) - errorcode: 14
2017-12-28 00:38:58: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:58: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:38:59: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:38:59: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_files.db-shm) - errorcode: 14
2017-12-28 00:38:59: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:38:59: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:00: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:00: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_files.db-shm) - errorcode: 14
2017-12-28 00:39:00: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:00: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:01: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:01: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_files.db-shm) - errorcode: 14
2017-12-28 00:39:01: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:01: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:02: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:02: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_files.db-shm) - errorcode: 14
2017-12-28 00:39:02: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:02: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file
2017-12-28 00:39:02: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_link_journal.db-shm) - errorcode: 14
2017-12-28 00:39:02: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:03: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:03: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_link_journal.db-shm) - errorcode: 14
2017-12-28 00:39:03: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:03: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:04: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:04: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_link_journal.db-shm) - errorcode: 14
2017-12-28 00:39:04: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:04: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:05: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:05: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_link_journal.db-shm) - errorcode: 14
2017-12-28 00:39:05: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:05: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:06: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:06: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_link_journal.db-shm) - errorcode: 14
2017-12-28 00:39:06: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:06: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:07: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:07: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_link_journal.db-shm) - errorcode: 14
2017-12-28 00:39:07: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:07: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file
2017-12-28 00:39:07: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:08: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:08: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_link_journal.db-shm) - errorcode: 14
2017-12-28 00:39:08: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:08: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:09: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:09: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_link_journal.db-shm) - errorcode: 14
2017-12-28 00:39:09: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:09: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:11: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:11: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_link_journal.db-shm) - errorcode: 14
2017-12-28 00:39:11: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:11: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:12: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:12: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_link_journal.db-shm) - errorcode: 14
2017-12-28 00:39:12: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:12: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:13: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:13: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_link_journal.db-shm) - errorcode: 14
2017-12-28 00:39:13: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:13: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file
2017-12-28 00:39:13: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_links.db-shm) - errorcode: 14
2017-12-28 00:39:13: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:14: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:14: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_links.db-shm) - errorcode: 14
2017-12-28 00:39:14: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:14: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:15: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:15: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_links.db-shm) - errorcode: 14
2017-12-28 00:39:15: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:15: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:16: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:16: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_links.db-shm) - errorcode: 14
2017-12-28 00:39:16: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:16: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:17: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:17: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_links.db-shm) - errorcode: 14
2017-12-28 00:39:17: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:17: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:18: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:18: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_links.db-shm) - errorcode: 14
2017-12-28 00:39:18: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:18: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file
2017-12-28 00:39:18: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:19: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:19: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_links.db-shm) - errorcode: 14
2017-12-28 00:39:19: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:19: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:20: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:20: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_links.db-shm) - errorcode: 14
2017-12-28 00:39:20: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:20: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:21: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:21: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_links.db-shm) - errorcode: 14
2017-12-28 00:39:21: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:21: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:22: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:22: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_links.db-shm) - errorcode: 14
2017-12-28 00:39:22: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:22: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:23: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:23: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_links.db-shm) - errorcode: 14
2017-12-28 00:39:23: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:23: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file
2017-12-28 00:39:23: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_settings.db-shm) - errorcode: 14
2017-12-28 00:39:23: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:24: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:24: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_settings.db-shm) - errorcode: 14
2017-12-28 00:39:24: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:24: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:25: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:25: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_settings.db-shm) - errorcode: 14
2017-12-28 00:39:25: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:25: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:26: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:26: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_settings.db-shm) - errorcode: 14
2017-12-28 00:39:26: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:26: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:27: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:27: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_settings.db-shm) - errorcode: 14
2017-12-28 00:39:27: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:27: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:28: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:28: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_settings.db-shm) - errorcode: 14
2017-12-28 00:39:28: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:28: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file
2017-12-28 00:39:28: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:29: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:29: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_settings.db-shm) - errorcode: 14
2017-12-28 00:39:29: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:29: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:30: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:30: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_settings.db-shm) - errorcode: 14
2017-12-28 00:39:30: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:30: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:31: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:31: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_settings.db-shm) - errorcode: 14
2017-12-28 00:39:31: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:31: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:32: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:32: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_settings.db-shm) - errorcode: 14
2017-12-28 00:39:32: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:32: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:33: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:33: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server_settings.db-shm) - errorcode: 14
2017-12-28 00:39:33: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:33: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file
2017-12-28 00:39:33: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:33: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:34: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:34: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:34: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:34: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:35: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:35: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:35: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:35: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:36: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:36: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:36: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:36: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
Is this a bug?
Another question btw: Is there a mechanism to scan the local directory for missing backups? Just to update the DB? I dont want to have dead backups laying around :open_mouth:
Server and Clients are on the latest software version available (2.1.20 Server and 2.1.17 Clients)
And the last part of the messages:
2017-12-28 00:39:37: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:37: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:37: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:37: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:38: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:38: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:38: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:38: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: unable to open database file
2017-12-28 00:39:38: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:39: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:39: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:39: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:39: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:40: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:40: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:40: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:40: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:41: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:41: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:41: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:41: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:42: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:42: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:42: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:42: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:43: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:43: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:43: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:43: ERROR: Error preparing Query [PRAGMA cache_size = -2048]: unable to open database file
2017-12-28 00:39:43: WARNING: SQLite: statement aborts at 4: [ATTACH DATABASE ‘urbackup/backup_server_settings.db’ AS settings_db] unable to open database file errorcode: 14
2017-12-28 00:39:43: ERROR: Error in CQuery::Execute - unable to open database file Stmt: [ATTACH DATABASE ‘urbackup/backup_server_settings.db’ AS settings_db]
2017-12-28 00:39:43: ERROR: SQL: unable to open database file Stmt: [ATTACH DATABASE ‘urbackup/backup_server_settings.db’ AS settings_db]
2017-12-28 00:39:43: ERROR: Error preparing Query [SELECT tvalue FROM misc WHERE tkey=?]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:44: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:44: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:44: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:44: ERROR: Error preparing Query [SELECT tvalue FROM misc WHERE tkey=?]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:45: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:45: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:45: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:45: ERROR: Error preparing Query [SELECT tvalue FROM misc WHERE tkey=?]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:46: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:46: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:46: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:46: ERROR: Error preparing Query [SELECT tvalue FROM misc WHERE tkey=?]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:47: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:47: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:47: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:47: ERROR: Error preparing Query [SELECT tvalue FROM misc WHERE tkey=?]: unable to open database file. Retrying in 1s…
2017-12-28 00:39:48: WARNING: SQLite: cannot open file at line 33991 of [a65a62893c] errorcode: 14
2017-12-28 00:39:48: WARNING: SQLite: os_unix.c:33991: (13) open(/usr/local/var/urbackup/backup_server.db-shm) - errorcode: 14
2017-12-28 00:39:48: WARNING: SQLite: unable to open database file errorcode: 14
2017-12-28 00:39:48: ERROR: Error preparing Query [SELECT tvalue FROM misc WHERE tkey=?]: unable to open database file
Segmentation fault
My first reaction is that it could be a permissions problem. Have you made sure that the database files are owned by user and group “urbackup”? I ran into some similar problems when I copied the UrBackup database files to a new system with rsync. I had to manually chown them to get UrBackup to start up.
Regarding your other question:
I was confused about this as well, but it appears that the command urbackupsrv remove-unknown does both things you want: it removes orphan entries from the database, and also deletes orphan files from disk (where no db references exist). So you’re on the right track by using this command.
Hi @aj_potc,
thank you for your answer. I get your point with the permissions.
The point is, urbackup has some localbackups of the database. When the mointpoint get lost, the software restores the DB from backup I suggest and placed it in the directory (but in hte wrong volume. After I fixed the error, the mointpoint on that folder (which is correct) has “overwritten” (not really, files are still there) the .db files and so on, so urbackup uses the older verion of the database I suggest from ~6hours before.
Then I have copied all the files to the original directory, but the DB not, as I suggested at that point, that this could cause data loss.
I have simply copied the data with a “cp” so I assume permissions are correct, but I will double check that.
To the second point -> If that is the case, wonderful :wink:
I have a graphic in the GUI where I can see a storage drop of 50%, and an increase to the normal amount later, so this might be really the case. Would be great if this “cleanup” does it right.
Thank you!
I’d suggest using the latest version of the database you can find. It’s possible with the changing mountpoints and your manual copy operation that something was modified with the permissions.
In any case, the remove-unknown command should sort it out, assuming your database isn’t totally corrupted.
backups are still working for most of the clients. For the other ones I suggest other problems.
The errors will be corrected this evening, I will report back if I was successful.
Hi again,
so I have looked in some errors.
From client backups:
Often the error is a “.dir_metadata” which is missing, so I cannot see them on the server itself. Maybe this is temporary or so? Might not to be important, but is throwing these errors. Nevertheless, db is not corrupt, as I used the working version, which has no information about some new information. The remove command should have corrected this.
From the error messages above:
This is the file which belongs to the errors:
307305 25 -rw-r–r-- 1 root urbackup 65536 Jan 3 18:18 backup_server.db-shm
Like all other files this is owned by root and the group of urbackup. I run the command as root, did I have to change to urbackup as a user?
Cheers
If urbackup runs as root normally, maybe running remove-unknown as root fixes it (per default it runs as user urbackup).
urbackupsrv remove-unknown -u root
I would try uroni’s suggestion first (as he is the software developer).
But on my installation, the file you listed does not have the same permissions. All files in my server’s /var/urbackup directory are owned by user urbackup and group urbackup, and this is the user under which UrBackup runs. I think that should be the default – at least it is on all other CentOS 7 systems where I’ve installed UrBackup. But of course it matters whether you’re running UrBackup under root or under its own user. So you should definitely check on that before making any changes to permissions.
Hi @uroni, @aj_potc,
I am running this as a FreeBSD jail (FreeNAS) and this permissions are the default for everything I see within urbackup. worked for me sofar. Only when it comes to the installation, the user and the the group urbackup has to be added manually, otherwise the installation procedure fails.
So I have run what uroni has suggested, and it worked:
2018-01-05 20:59:58: Going to remove all unknown files and directories in the urbackup storage directory. Waiting 20 seconds…
2018-01-05 21:00:18: Shutting down all database instances…
2018-01-05 21:00:18: Opening urbackup server database…
2018-01-05 21:00:18: Testing if backup destination can handle subvolumes and snapshots…
Testing for btrfs…
Testing for zfs…
2018-01-05 21:00:18: Backup destination cannot handle subvolumes and snapshots. Snapshots disabled.
2018-01-05 21:00:18: Cleaning up 0 percent
2018-01-05 21:00:18: Cleaning up 0 bytes on backup storage
2018-01-05 21:00:18: Database cache size is 200 MB
2018-01-05 21:00:18: Starting cleanup…
2018-01-05 21:00:18: Freeing database connections…
2018-01-05 21:00:18: Enough free space now.
2018-01-05 21:00:18: Client with id=1 has 1 full image backups max=5
2018-01-05 21:00:18: Client with id=1 has 0 incremental image backups max=30
2018-01-05 21:00:18: Client with id=2 has 3 full image backups max=5
2018-01-05 21:00:18: Client with id=2 has 4 incremental image backups max=30
2018-01-05 21:00:18: Client with id=4 has 2 full image backups max=5
2018-01-05 21:00:18: Client with id=4 has 4 incremental image backups max=30
2018-01-05 21:00:18: Client with id=6 has 1 full image backups max=5
2018-01-05 21:00:18: Client with id=6 has 0 incremental image backups max=30
2018-01-05 21:00:18: Client with id=7 has 1 full image backups max=5
2018-01-05 21:00:18: Client with id=7 has 1 incremental image backups max=30
2018-01-05 21:00:18: Client with id=1 has 1 full file backups max=4
2018-01-05 21:00:18: Client with id=1 has 0 incremental file backups max=100
2018-01-05 21:00:18: Client with id=4 has 1 full file backups max=4
2018-01-05 21:00:18: Client with id=4 has 15 incremental file backups max=100
2018-01-05 21:00:18: Client with id=2 has 1 full file backups max=4
2018-01-05 21:00:18: Client with id=2 has 21 incremental file backups max=100
2018-01-05 21:00:18: Client with id=7 has 1 full file backups max=4
2018-01-05 21:00:18: Client with id=7 has 3 incremental file backups max=100
2018-01-05 21:00:18: Deleting old logs…
2018-01-05 21:00:18: Done deleting old logs
2018-01-05 21:00:18: Cleaning history…
2018-01-05 21:00:18: Rewriting daily history…
2018-01-05 21:00:18: Reading history…
2018-01-05 21:00:18: 69 history items read
2018-01-05 21:00:18: Deleting history…
2018-01-05 21:00:18: Writing history…
2018-01-05 21:00:18: Rewriting monthly history…
2018-01-05 21:00:18: 4 history items read
2018-01-05 21:00:18: Rewriting yearly history…
2018-01-05 21:00:18: 0 history items read
2018-01-05 21:00:18: Done cleaning history
2018-01-05 21:00:18: Cleaning deleted backups history…
2018-01-05 21:00:18: Done cleaning deleted backups history.
2018-01-05 21:00:18: Cleaning up client lists…
2018-01-05 21:00:18: Done cleaning up client lists.
2018-01-05 21:00:18: Updating statistics…
2018-01-05 21:00:18: Updating image stats…
2018-01-05 21:00:18: Updating file statistics…
2018-01-05 21:00:18: Done updating statistics.
2018-01-05 21:00:18: Cleanup successfull.
2018-01-05 21:00:18: Removing unknown for client “xxxx”
2018-01-05 21:00:19: Removing unknown for client “xxxx”
2018-01-05 21:00:37: Removing unknown for client “xxxx”
2018-01-05 21:00:37: WARNING: File backup “180102-2007” of client “xxxx” not found in database. Deleting it.
2018-01-05 21:00:39: Removing unknown for client “xxxx”
2018-01-05 21:00:39: Removing dangling file entries…
2018-01-05 21:00:39: Deleted 0 file entries
2018-01-05 21:00:39: Successfully removed all unknown files in backup directory.
Thank you!
This should have cleaned everything up.
